error in executing panid command
hi i did the setup according to border router setup guide on Nordic info center. all run fine but when i tried to run command ""panid 0xabcd" it saying not foundimage description
  • Hi
    If all you need is a single board running the thread CLI example, then the hardware setup is very simple. You just need a single nRF52840 board connected to your PC over USB.
    To access the board you should connect to the virtual comport that shows up when you power up the kit.
    In the screenshot you sent it appears you have SSH'ed into the RPi, rather than connect to the virtual comport of the Thread CLI node.
    Best regards
