Is heart rate service the correct thing to use for power consumption efficiency?
I am developing some firmware using SDK 8.1 where power consumption is absolutely critical. The firmware will make a ble connection between the central and peripheral device and after that does almost nothing except for every couple months the peripheral will send it's battery level to the master device. I am wondering if it makes sense to use the heart rate service for this? My gut tells me know since I figure it probably is a power hungry service. I could be wrong though. Basically, I am asking what the most power efficient way to send a small piece of data from the peripheral to the central every couple of months would be.
  • First note: if power consumption is so critical why you don't use the best available HW and SW (= nRF52, S132 stack and nRF SDK v14 - in case you really really need to stick with nRF51 then S130 and SDK V12.3.0)?
    To your main question: it seems that you know what is exact profile of your application activity over time (what adv. interval you want to use, when the device will be ACTIVE/POWER ON SLEEP/POWER OFF, when/how long/what parameters will be used when under connection) then you can do some modelling and find out which of these modes will contribute dominantly to your power consumption. Then optimize your profile with this in mind. It would be kind of dumb to advise just based on feelings (which is what we do here right now I'm afraid... "my FW does almost nothing except little bit of this and that...")
  • Where can I find the information on what chips are compatible with which SDK versions and SoftDevices?
