Getting an error when trying to build Bluetooth Mesh examples on macOS
The problem
I am trying to build the examples contained in Bluetooth Mesh stack, but I get the following error when running cmake:
-- Found assembler: /usr/local/bin/arm-none-eabi-gcc
-- Check for working C compiler: /usr/local/bin/arm-none-eabi-gcc
-- Check for working C compiler: /usr/local/bin/arm-none-eabi-gcc -- broken
CMake Error at /Applications/CMake.app/Contents/share/cmake-3.10/Modules/CMakeTestCCompiler.cmake:52 (message):
  The C compiler
    "/usr/local/bin/arm-none-eabi-gcc"
  is not able to compile a simple test program.
##What I do Here are the steps I take to try to build the examples:
  • I download the Mesh SDK from www.nordicsemi.com/.../nRF5-SDK-for-Mesh
  • I unzip the file
  • Using the terminal: cd nrf5_SDK_for_Mesh_v1.0.0_src; mkdir build; cd build;, and
  • cmake -DPLATFORM=nrf52832_xxAA -DTOOLCHAIN=gccarmemb -DSOFTDEVICE=s132_5.0.0 ..
##More information about my setup
  • macOS High Sierra 10.13.2
  • nrf5_SDK_for_Mesh_v1.0.0_src
  • CMake version 3.10.1
  • gcc-arm-none-eabi-7-2017-q4-major (NOTE: /usr/local/bin/arm-none-eabi-gcc is a symbolic link to {somewhere on my system}/gcc-arm-none-eabi-7-2017-q4-major/bin/arm-none-eabi-gcc)
  • Hi f0corner,
    I'm suspecting that the issue is with the symbolic link to arm-none-eabi-gcc. It might be that it's not finding the rest of the arm-none-eabi-* files and/or the standard library. I'd suggest to try adding the gcc-arm-none-eab-7-2017-q4-major/bin/ to your PATH or to ensure that everything in gcc-arm-none-eab-7-2017-q4-major/bin/ has a link in /usr/local/bin.
    On my MacOS, I'm using Homebrew to install arm-none-eabi-gcc.
    Best,
    Thomas
  • Hi f0corner,
    Best,
    Thomas
