nRF8001 AVR Programming
Hello - I tried looking for my answer here but didn't really get what I need. I'm also relatively new to all of this.
I purchased the Adafruit's nRF8001 bluetooth module and would like to interface it with my Atmega328p microcontroller. So far what I have done is wired up the module with my uC using the proper SPI pins.
Now I'm trying to communicate with it, and I'm a little stuck. What I want to do is to send the Test System command.
    #define BLE_DDR			DDRB
#define BLE_PORT 		PORTB
#define BLE_PIN			PINB
#define BLE_SCK 		PB5
#define BLE_MISO 		PB4
#define BLE_MOSI 		PB3
#define BLE_RDY 		PB2
#define BLE_REQ 		PB1
#define BLE_RST 		PB0
//SPI registers
#define SPI_CTRL_REG 	SPCR
#define SPI_STAT_REG 	SPSR
#define SPI_DATA_REG 	SPDR
#define SPI_ENABLE 		SPE
#define SPI_MASTER 		MSTR
#define SPI_CLK_DIV_16 	SPR0
#define SPI_INTERRUPT	SPIF
int main() {
	initUSART();
	//initialize SPI communication
	BLE_DDR |= ((1 << BLE_MOSI) | (1 << BLE_SCK) | (1 << BLE_REQ) | (1 << BLE_RST));
	BLE_PORT |= ((1 << BLE_RDY) | (1 << BLE_MISO));
	SPI_CTRL_REG |= ((1 << SPI_ENABLE) | (1 << SPI_MASTER) | (1 << SPI_CLK_DIV_16));
	BLE_PORT |= (1 << BLE_REQ);
	_delay_ms(100);
	//communicate to bluetooth via SPI
	//turn on test mode on BLE
	uint8_t len = 0x02;
	// uint8_t op = 0x01;
	// uint8_t data = 0x02;
	//send it
	_delay_ms(5000);
	BLE_PORT &= ~(1 << BLE_REQ);
	//wait until ble is ready to receive data
	loop_until_bit_is_clear(BLE_PIN, BLE_RDY);
	printString("sending len\r\n");
	SPI_DATA_REG = len;
	loop_until_bit_is_set(SPI_STAT_REG, SPI_INTERRUPT);
	printString("done\r\n");
	return 0;
From the datasheet, I need to set the Request line to low in order to begin the communication with the BLE module. However, it appears that I am stuck forever waiting for the RDY line to go low as well, so it will never send the data across the SPI line.
I've read the important bits of the ATMEL and nRF8001 datasheets but came up empty.
Is there something that I have overlooked? If I'm doing this completely wrong, can you point me in the right direction?
Many thanks!
