app_sched_execute followed by sd_app_evt_wait
I am working on a project based on the nRF51822 with the softdevice S110.
I am trying to develop an application using the main loop provided in an example application:
// Enter main loop
for (;;)
    app_sched_execute();
    <<-- interrupt raised here that calls app_sched_event_put
    sd_app_evt_wait();
I am puzzled by this code for the idle loop, I do not understand how the system handles a situation where an interrupt is raised between the execution of app_shed_execute and sd_app_evt_wait. If the interrupt invokes a app_sched_event_put, then the system will still go to (deep) sleep mode and will not execute the event handler until the next loop which could come much later. Am I missing something in the architecture?
Thanks Louis
  • Did you read this?
    /**@brief Waits for an application event.
     * An application event is either an application interrupt or a pended interrupt when the
     * interrupt is disabled. When the interrupt is enabled it will be taken immediately since
     * this function will wait in thread mode, then the execution will return in the application's
     * main thread. When an interrupt is disabled and gets pended it will return to the application's
     * thread main. The application must ensure that the pended flag is cleared using
     * ::sd_nvic_ClearPendingIRQ in order to sleep using this function. This is only necessary for
     * disabled interrupts, as the interrupt handler will clear the pending flag automatically for
     * enabled interrupts.
     * In order to wake up from disabled interrupts, the SEVONPEND flag has to be set in the Cortex-M0
     * System Control Register (SCR). @sa CMSIS_SCB
     * @note If an application interrupt has happened since the last time sd_app_evt_wait was
     *       called this function will return immediately and not go to sleep. This is to avoid race
     *       conditions that can occur when a flag is updated in the interrupt handler and processed
     *       in the main loop.
     * @post An application interrupt has happened or a interrupt pending flag is set.
     * @retval ::NRF_SUCCESS
    SVCALL(SD_APP_EVT_WAIT, uint32_t, sd_app_evt_wait(void));
  • Hello Nikita,
    Thanks and sorry, I had missed the note.
    If I understand correctly the note, it means that this main loop code is safe from race conditions: the system monitored interrupt handlers that were invoked outside of the wfe background wait and it will not wait if this was the case. Is my understanding correct?
    Thanks
    Louis
