Real time data compression
To compress the real time data in nRF52832 which algorithm is more preferable and why ?
  • Hi Faizan,
    Real time data compression is dependent on more than just which MCU you are using. The answer can change depending on many factors including
    • Sampling rate
    • Data type ex. (uint32 vs int32)
    • Signal type ex. (audio vs EEG)
    • Desired compression percentage
    • Importance of decompression vs compression efficiency
    • How much loss you can afford
    Because of the number of cases, it will be hard to expect a good answer here. Especially without specific application info. I would recommend starting some private research on the topic or finding a consultant to get you started.
