SDK14.2 nRF52840 order of connection handles
Hi All, I use 2 peripheral and 6 Central roles coexisting. Not clear the order of conn_handle number assigned by SD during BLE Connection.
For example. After Central Connection, the conn_handle is 0x0001 Then, After Peripheral Connection, conn_handle is 0x0000 etc.. What algorithm used? 1, 0, 2, .... etc ?
thx!
  • Initially the connection handles are sequential. However, as devices disconnect (leaving handles unused) the handles are "recycled".
  • ANYONE can answer the question ? why it is haotic , NOT sequential ?
    this is very important issue.
    thx.
  • Ok, maybe I misunderstood your first post. If you have a device configured to handle 2 peripheral links and 6 central links, the peripheral links will use connection handle 0 and 1, while the central links will use connection handle 2-7.
    However, this is not a documented behaviour and it might work differently in future Softdevice releases. Hence, it is not recommendable to base your code on this.
  • OK, now clear, thx !
