low power input interrupt
Hi
I am using gpio for input interrupt as below
nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_HITOLO(true);
in_config.pull = NRF_GPIO_PIN_PULLUP;
err_code = nrf_drv_gpiote_in_init(PIN_IN, &in_config, in_pin_handler);
nrf_drv_gpiote_in_event_enable(PIN_IN, true);
it is working fine but consume more power. if I do not use that then power consumption reduce to 8ua to 9ua is there any other low power interrupt enable method?
I have read about use the PORT event to trigger a pin interrupt without increasing the current consumption. But don't know how to use that.is there any example that have used PORT event to trigger a pin interrupt?
Thanks
