What SDK do I need to compile some blinky app with ANT?
I am new to nRF programming. My "far away goal" is to make a BLE sensor mesh with a centralised data collection.
Currently I am deciding what libraries to start playing with. ANT seems to be quite usable and so I would like to get an overview of what SDK or software tools do I need to compile/flash some simple "blinky" app using ANT.
I have 3 nRF52 DK boards. I have downloaded the nRF SDK 14.2.0 and flashed a blinky app on the DK. I have read a little bit through the example source codes. I am used to write a code using a "primitive" editors like Notepad++, not using IDEs like Keil or Eclipse.
The questions are:
  1. What else, except ANT source code itself, do I need to start playing?
  2. Is there a way to simply download an ANT source without becoming an "ANT+ Adopter"?
  3. Are there some other alternative libs to ANT that incorporate the BLE mesh functionality?
    I'm not sure if you have realized this yet, but ANT does not "incorporate the BLE mesh functionality". ANT is a proprietary 2.4 GHz protocol developed by Dynastream, mostly used for sports equipment etc. ANT does support mesh topology, and if you only want to look into building a mesh setup this could be useful, but it will not be compatible with the Bluetooth Mesh. If you want to build a Bluetooth based mesh, ANT is not the correct place to start. You should have a look at the nRF5 SDK for Mesh, and the Light switch demo.
    Jørgen
  • Great infos. As I understood correctly, the main difference between ANT and BLE mesh is more-or-less the robustness and security. ANT has a simpler stack than BLE and uses weaker security key. IMHO this limits the usage of ANT (although the usage range can be still very wide).
    And what about pricing? I have read that the license for ANT costs around $0.08 per device in production. But haven't found any pricing for BLE. Do you know something about this?
    And why should I decide to use nRF OpenMesh prior to BLE Mesh itself? What benefits do I gain with the OpenMesh?
