sd_power_system_off() cause reboot
I write this code to set my ble device power down,but it causes reboot without any error report.
     GPIO_WAKEUP_BUTTON_CONFIG(LEFT_BUTTON_PIN_NO);
     GPIO_WAKEUP_BUTTON_CONFIG(RIGHT_BUTTON_PIN_NO);
when I comment out this two lines
       //GPIO_WAKEUP_BUTTON_CONFIG(LEFT_BUTTON_PIN_NO);
       //GPIO_WAKEUP_BUTTON_CONFIG(RIGHT_BUTTON_PIN_NO);
power down worked,but could not wake up from this two button
I try to add
	err_code = app_button_enable();
befor call sd_power_system_off() but fail too.
Is that right ? if I want wake it up by set the pin from high to low.
  • Yes I am using SDK 4.4.2 my chip now is not support the latest version of SDK
    Should I PULL UP this pin before I entering system off?
    I find that GPIO_WAKEUP_BUTTON_CONFIG do
    GPIO_PIN_CONFIG(PIN_NO,
    GPIO_PIN_CNF_DIR_Input,
    GPIO_PIN_CNF_INPUT_Connect,
    GPIO_PIN_CNF_PULL_Disabled,
    GPIO_PIN_CNF_DRIVE_S0S1,
    GPIO_PIN_CNF_SENSE_Low);
    } while (0)
    Do GPIO_PIN_CNF_PULL_Disabled will cause instable? Can I set is to PULL_UP?
    } while (0)
