Characteristic Value Read
Hello together,
i know, there are similar questions about "Reading Characteristic Value", but i don't get a solution for me. My Problem: I use nRF51DK with SD130 and the Example Project from the Characteristics Tutorial. I added 1 service and 2 characteristics with each 5 bytes.
image description
Service: UUID: 0x2800 Handle: 0x000C
Char Decl. UUID: 0x2803 Handle: 0x000D
Char Value: UUID: 0x0001 Handle: 0x000E Array: 01-02-03-00-00
Char2 Decl. UUID: 0x2803 Handle: 0x000F
Char2 Value: UUID: 0x0002 Handle: 0x0010 Array: 00-00-00-00-00
I set the permissions for read and write and i can read out and change the values with my smartphone. Now i want to do something with this 10(2x5) bytes from the peripheral device. And here is my problem. I need them at different times while running, not only when writing/written, and i dont get it, to read these bytes out.
I tried this in the main loop for a simple test to read the value 01-02-03-00-00 of Char1:
   	ble_gatts_value_t *  	temp;
    memset(&temp, 0, sizeof(ble_gatts_value_t));
    err_code = sd_ble_gatts_value_get(BLE_CONN_HANDLE_INVALID, 0x000E, temp);
But i only get the err_code 0x00000010.
image description
I hope u understand what i mean/need. Perhaps you can help me. Thanks a lot.
  • 0x00000010 = NRF_ERROR_INVALID_ADDR, which for function sd_ble_gatts_value_get means that Invalid pointer supplied. Temp is only the pointer to the ble_gatts_value_t, but where physically is that value stored? Please try changing temp type to ble_gatts_value_t (instead of ble_gatts_value_t*)...
  • Hi Wojtek, ok that was really embarrassing, i changed it. Now no error occurs. But when i view at temp, i only get an empty p_value 0x00000000 with the correct len of 0x0005 (5Bytes)!?
  • FormerMember
    0 FormerMember
    ble_gatts_value_t is defined the following way:
    typedef struct
      uint16_t  len;
      uint16_t  offset;
      uint8_t   *p_value;
    } ble_gatts_value_t;
    In your example, in order to make temp contain the value of the attribute after calling sd_ble_gatts_value_get(), p_value in ble_gatts_value_t has to be set to point to a location:
    uint8_t location_for_my_value;
    temp.p_value   = &location_for_my_value;
    temp.len      = number_of_bytes_you_want_to_read;
    temp.offset   = 0;
    err_code = sd_ble_gatts_value_set(BLE_CONN_HANDLE_INVALID, 0x000E, temp);
    To make the code more robust, I would recommend you to refer to the reference for the attribute handle value, rather than hard code the handle value. For retrieving the battery level value in the ble_app_hrs example in the SDK, it would be the following:
    err_code = sd_ble_gatts_value_set(m_conn_handle,m_bas.battery_level_handles.value_handle, temp);
  • Hi Kristin, thank you. I think, i now understand this function with the ble_gatts_value_t struct. So i have changed my code to yours. When i run this code, after the sd_ble_gatts_value_get() the "location_for_my_value" value should contain the value from the characteristic!? But even when i change the characteristic value to AA-AA-AA-AA-AA, the "location_for_my_value" contains 0x00 from memset() :-/
  • Ok, i dont know why, but after i erased Region 0(SD) and Region 1(APP) and flashed it again it's running correctly. :) thx!!
