external crystal
Hello is a starter developer I used the nrf51822 chip on the pcb board and downloaded the example code but it did not work. When I checked the 16mhz external crystal on the pcb board, the clock was not being generated. I knew there was no need to write code to use external crystals. Do you have to set an external clock with the code? Please advise.
