Long connection delay with Android, iOS superfast
i have the following setup: nrf52 as peripheral, smartphone as central. Peripheral's purpose is to be an interface between appliance and smartphone. It has no pairing/bonding feature and it advertises with 22ms interval and public static address.
While iOS always performs connection in about 200ms, Android is very inconsistent. Sometimes it connects as fast as iOS, but most of the times it takes 4-5 seconds to get connected.
The peripheral has no low power restriction so it is setup to perform at its maximum, with connection interval, slave latency and supervisor timeout configured as low as possible, as defined in iOS Design Guidelines.
I have tried to analyze sniffer trace but there is no suitable information, the delay is seen between the connect action on Android, and the CONNECT_REQ on the sniffer.
I moved to HCI dump on Android side and i could see the delay, which looks like this:
    No.     Time                Prot.   Len  Info
    38272	1511777537.552557	HCI_CMD	 29	 Sent LE Create Connection
    38273	1511777537.556675	HCI_EVT	 7	 Rcvd Command Status (LE Create Connection)
    38274	1511777537.591402	HCI_EVT	 22	 Rcvd LE Meta (LE Connection Complete) //300ms, GOOD!
    74093   1511781742.368168	HCI_CMD	 29	 Sent LE Create Connection
    74094   1511781742.371541	HCI_EVT	 7	 Rcvd Command Status (LE Create Connection)
    74095   1511781746.930870	HCI_EVT	 22	 Rcvd LE Meta (LE Connection Complete)  //4.5s, BAD!
It can be seen that between frame 38273 and 38274 the delay is 0.3 seconds, while between 74093 and 74094 there is a 4.5 seconds time delay.
Android is connecting with autoConnect=false, so no backgound connection is performed.
This is the nordic sniffer trace, on a long connection delay case:
5430	49.623224000	Test_device	        <broadcast>		  54	ADV_IND
5431	49.692073000	Test_device	        <broadcast>		  54	ADV_IND
5432	49.698782000	6a:15:34:0b:f7:e0	dc:2c:8c:aa:c3:f7 60	CONNECT_REQ
5433	49.704162000	Master	            Slave		      26	Empty Data PDU
5434	49.708205000	Slave	            Master		      26	Empty Data PDU
5435	49.712125000	Master	            Slave		      35	LL Control PDU: LL_FEATURE_REQ
5436	49.743382000	Master	            Slave		      35	LL Control PDU: LL_FEATURE_REQ
Between the last ADV packet (5431) and the CONNECT_REQ (5432) there is only a 6ms delay, which should mean that the delay is all at the Android side.
Can anyone explain why is this happening? Is there any margin of improvement?
Thank you
