DFU separate files. inside
nRF52, S132, SDK13.
I need flash two .hex files. One- firmware, second- data. It flashed on a factory. data- veans serial number and other personal chips info. Now I can separate those files and merged first like discribed: devzone.nordicsemi.com/.../
and merged with bootloader. After I can flash via nrf go studio second file with personal data. All works fine. But If I flash app_dfu_package.zip (prepared for first file) by DFU, nRF doesn't work more. I need flash app_dfu_package.zip and don't erase second file. How can I do it?
  • Hi Mikhail,
    What exactly you mean nRF doesn't work more ? Have you tried to debug if it can get to main() in the application ? Would it be the result of your application data being erased ?
    Where do you locate the your application data ? If you want to preserve your data you need to follow this guide.
    Note that the bootloader assume the application data starts right before the beginning of the bootloader.
    Make sure you also count the room for fds data if you use that module (by default used by peer manager)
  • Hi!
    • if struct located in the first start address (0x1F800)- all works correct. Also merged bootloader is job. I can make DFU and new image (.zip) works good. But we now talk that I just flash this merged file via j-link. And in the case of struct located by 0x77000 addr- always reboot.
    • Yes. I use RTT debug and right after main() and LOG init
      NRF_LOG_INFO("nInside main\r\n");
    And after flash I see this string again and again proof
    • third question- I don't know how to catch it.
  • Hi!
