#BluetoothMesh OOB authentication
I hope Nordic Semiconductor is working on #BluetoothMesh provisioner & configuration App like Silicon Labs already has.
But could anybody inform me, how you are going to implement OOB authentication which happens during provisioning process ?
Currently I am testing Zephyr OS #BLEMesh (running on nrf52840-PDK) using Silicon Labs Mesh App. I'm able to replicate this www.youtube.com/watch demo using #nRF52840-PDK.
In this case, to complete OOB authentication during provisioning process I have to access serial terminal of nRF52 to read a number which is alloted my APP. It is like mobile OTP verification. We can't use this method with actual products otherwise end-user have to connect device to serial-terminal to get that OOB number.
Mr. Johan Hedberg (Zephyr OS developer behind #BluetoothMesh ) gave me following reply when I asked him about it -
In the Mesh Profile Specification, you can find the other types of input
& output OOB actions e.g. under section 5.4.1.2, in particular tables
5.22 and 5.24. The only reason the Silicon Labs App uses display number/string
is that it is designed for a setup with a text-based console.
The general consensus within the Mesh WG is that the
input/output OOB action mechanism is not sufficiently secure and should
only be considered to be a minor improvement over non-interactive
provisioning. The recommendation for secure provisioning is to use OOB
Public Key transfer or a 16-byte static OOB value. The actual mechanism
to do this is left up to the implementation - you can e.g. have a URL in
the node's advertising data or have a QR code printed on the node which
the provisioner reads. Using NFC is another option. IIRC, there should
be a whitepaper coming out from the Mesh WG soon which covers
recommended practices for secure provisioning.
Any other additional information will be appreciated !!
Thank You!!
