connection param update on ble_app_multirole_lesc
In this example project
nRF5_SDK_12.3.0_d7731ad\examples\ble_central_and_peripheral\experimental\ble_app_multirole_lesc\main.c
        cp_init.start_on_notify_cccd_handle    = BLE_CONN_HANDLE_INVALID; // Start upon connection.
        cp_init.disconnect_on_fail             = true;
        cp_init.evt_handler                    = NULL;  // Ignore events.
You assigned BLE_CONN_HANDLE_INVALID(which is defined to 0xFFFF in ble_types.h) to start_on_notify_cccd_handle ,and according your comments ,it will start param update timer on ble connection .
But on its response function , you compare this value with BLE_GATT_HANDLE_INVALID(defined to 0x0000 in ble_gatt.h file)
static void on_connect(ble_evt_t * p_ble_evt)
    // Save connection parameters
    m_conn_handle         = p_ble_evt->evt.gap_evt.conn_handle;
    m_current_conn_params = p_ble_evt->evt.gap_evt.params.connected.conn_params;
    m_update_count        = 0;  // Connection parameter negotiation should re-start every connection
    // Check if we shall handle negotiation on connect
    if (m_conn_params_config.start_on_notify_cccd_handle == BLE_GATT_HANDLE_INVALID)
        conn_params_negotiation();
So. It's definitely can't update connection parameter to Master no mater what paramter is set in CONNECTION_REQ. Is this a bug or any other reason you write this?
