Adding ARM math library to Segger's nRF52 BLE projects - check __FPU_PRESENT compile error
Hi there~. I tried Nordic's FFT example (SDK 14.2) with a PCA10040 board. So I tried to add that FFT related codes in the heart rate peripheral example. I use the Segger's Embedded Studio 3.30 (SES) on Windows 10 PC.
FFTPre
I compared the preprocessors listed.
PRE00
The heart rate example didn't had the ARM_MATH_CM4 preprocessor, so I added it manually. However, SES threw a compiler error.
SESError
Segger: Adding __FPU_PRESENT to the C/C++ > Preprocessor > Preprocessor Definitions project property if the device you are using has an FPU.
So I manually added the __FPU_PRESENT preprocessor and it was buildable.
PRE11
This build error problem is not my concern. My curious point is that, Nordic's FFT example was buildable even though the project didn't use the __FPU_PRESENT preprocessor. What options were configured to build the SES project, which uses ARM math library and FPU, without using the __FPU_PRESENT preprocessor?
HI
Hi, everybody~ I have created a Google Drive shared link. I figured out how to generate this error! After downloading it, browse nRF5_SDK_14.2.0_17b948a\examples\ble_peripheral\ble_app_hrs\pca10040\s132\ses, and open the SES project, please. Or you can try the Keil MDK 5 project, too.
#include "arm_math.h"
#include "arm_const_structs.h"
If I include the above header files, in main.c, the compiler error doesn't appear. So I created my_foo.c source file. If I include those header files in other source files, it generates the error!
QUESTION: When creating other source files, what extra configurations are needed to include those header files?
  • Hi MatthewKYEO!
    You should be able to find the #define __FPU_PRESENT 1 in the nrf52.h header file.
    It should be set to 1 in your HRS example as well, but you can verify that it is.
    Best regards.
  • Hello, Joakim.
    This looks strange. Both HRS project and FPU_FFT(S132) project uses the nRF5_SDK_14.2.0_17b948a/components/device/nrf52.h
    and it is commonly defined that #define __FPU_PRESENT 1.
    Then why does the #error "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)" appear
    if I don't manually define __FPU_USED in the Embedded Studio's preprocessor menu?
    Since both projects use the same nrf52.h file, adding this looks unnecessary to me.
    Aren't we missing other configuration difference between two projects?
    -Regards, MANGO
  • Hi MANGO!
    Do you have the same problem as Matthew?
    I'm not aware of any other configurations, I couldn't find anyone either.
    I'll see what I can find out and get back to you.
    Joakim.
  • Hi, Joakim.
    • Do you have the same problem as Matthew? RE: Yes. I was using the NUS (Nordic UART Service) example and tried to combine the FFT example.
    I observed the same compiler message.
    Can you try it on your side? Just like this question stated, I don't want to add __FPU_PRESENT in the preprocessor menu, either.
    -Regards, MANGO
  • I'm haven't been able to reproduce the error that you are seeing.
    Maybe you could upload your project/main file so I can test your project?
    Best regards.
