c# - nrfjprog.dll writing hex
Hi
I'm looking for an example on how to write a hex-file to SoC using nrfjprog.dll. The P/Invokes are all set and working fine.
I'm absolutely not familiar with python, but from pynrfjprog examples, I found, I need to split up the hex file in chunks and flash them to the SoC. pynrfjprog is using a helper library called Hex or IntelHex. Assuming I need a library like that to split up the hex file, I'm asking for hints on what library to use. I found those two, but I really can't figure out if it works anywhere close to what Python Hex/IntelHex does...
C# lib 1 : IntelHexFormatReader
C# lib 2 : net-intelhex-parser
Thanks
    At first glance it looks like the first library you link should be able to do the same job as IntelHex. Have you tried it?
    Jørgen
  • Hi
    meanwhile I solved this. I had to use lib 2, the net-intelhex-parser, but had to modify a couple things to make it work.
    Currently it is working fine and we are testing with different devices and configurations.
    Martin
