NRF_CCM->MICSTATUS bit not set, even though it's computed correctly
I'm developing a minimal bootloader on the nrf52832 that just reads/writes flash and decrypts some data already present in flash. I'm using the Bluetooth Spec's own sample data, specifically Sample Data 2 (Vol 2, Part G, 1.2.2 - p1547 of v5.0 spec).
K: 89678967 89678967 45234523 45234523
Initialization vector: 66778899 aabbccdd
Payload counter: 0000bc614e
Payload: 68696a6b 6c6d6e6f
T: 08d78b32
S0: b90f2b23 f63717d3 38e0559d 1e7e785e
MIC: b1d8a011
Encrypted payload: b0ae898a 6e6864d4
My code is derived from Nordic's CCM example. The differences are that I've added arguments to ccm_crypt_init() to pass a Key and Initialization Vector, and m_ccm_config.counter is hard-coded to start at the value given in the sample data.
I'm using Keil to look at memory while inside ccm_crypt_packet_decrypt(). Just before the function returns, clear_buffer[] contains the properly decrypted data, NRF_CCM->SCRATCHPTR points to the expected S0[0-3], and SCRATCHPTR+8 contains the expected T. The XOR of S0[0-3] and T is equal to the MIC passed appended to the end of Encrypted Payload. The problem is that NRF_CCM->MICSTATUS is still not set.
