Using the SPI example to communicate with a CR95HF
Good evening all, I'm trying to get my DK52 communicating with a CR95HF (this is a NFC controller with serial and SPI control interfaces), I'm using a breakout board - BM019
The CR95 requires a setup sequence to select the SPI interface image description
So far I'm using the SPI example from SDK 14, I have modified it to toggle the IRQ_IN pin I'm using pin30) on initialization, I then attempt to send 0x55 to the CR95 (this is a Echo command - I'm expecting 0x55 back). However I seem to get back 0x06 (the first two loops) then nothing for any additional requests)
I have tried removing my initialization toggle, when I do this I don't get anything back on any of the loops)
Here's my modified code.
#define SPI_INSTANCE  0
static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);
static volatile bool spi_xfer_done;
//#define TEST_STRING "Nordic"
//static uint8_t       m_tx_buf[] = TEST_STRING;
static uint8_t       m_rx_buf[2];  //sizeof(TEST_STRING) + 1];
static const uint8_t m_length = 1; //sizeof(m_tx_buf);
void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
                       void *                    p_context)
    spi_xfer_done = true;
    NRF_LOG_INFO("Transfer completed.");
    if (m_rx_buf[0] != 0)
        NRF_LOG_INFO(" Received:");
        NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
uint8_t hexdata = 0x55;
    bsp_board_leds_init();
    nrf_gpio_cfg_output(30);
    nrf_gpio_cfg_output(29);
    nrf_gpio_pin_set(30);
    nrf_delay_ms(3000);
    NRF_LOG_INFO("SPI example.");
    nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
    spi_config.ss_pin   = SPI_SS_PIN;
    spi_config.miso_pin = SPI_MISO_PIN;
    spi_config.mosi_pin = SPI_MOSI_PIN;
    spi_config.sck_pin  = SPI_SCK_PIN;
   nrf_gpio_pin_clear(30);
    nrf_delay_us(100) ;        // BM019 into SPI
    nrf_delay_ms(10) ;
    APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
    nrf_delay_ms(1000);
    while (1)
        // Reset rx buffer and transfer done flag
        memset(m_rx_buf, 0, m_length);
        spi_xfer_done = false;
        APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, &hexdata, m_length, m_rx_buf, m_length));
        while (!spi_xfer_done)
            __WFE();
        NRF_LOG_FLUSH();
        bsp_board_led_invert(BSP_BOARD_LED_0);
        nrf_delay_ms(1000);
and my output.
<info> app: SPI example.
<info> app: Transfer completed.
<info> app:  Received:
<info> app:  06                     |.
<info> app:  06                     |.
I have tried so many thing I'm starting to lose my mind on what I've done! (2 days now!!!) I think i'm initializing it but not 100% sure. I get that this might be a bit out of scope on the Nordic site but I'm thinking this is more a SDK issue!
  • Hi all! I am having exactly the same issue and don't know how to continue. I have also spend 2 days with this.
    I'm using SDK 15.0
    My SPI config is as follows:
        spi_config.ss_pin   = NRF_SPI_PIN_NOT_CONNECTED;
        spi_config.orc      = 0xFF;
        spi_config.mode      = NRF_DRV_SPI_MODE_0;
        spi_config.frequency = NRF_DRV_SPI_FREQ_1M;
        spi_config.bit_order = NRF_DRV_SPI_BIT_ORDER_MSB_FIRST;
        APP_ERROR_CHECK(nrf_drv_spi_init(&m_spi_master_0, &spi_config, spi_event_handler, NULL));
        nrf_gpio_pin_set(IRQ_PIN);
        nrf_gpio_pin_set(SPI_SS_PIN);
       // CR95HF Wake-Up Pulse
       nrf_delay_ms(10);                        // send a wake up
       nrf_gpio_pin_clear(IRQ_PIN);      // pulse to put the
       nrf_delay_us(100);
       nrf_gpio_pin_set(IRQ_PIN);     // mode
       nrf_delay_ms(10);
    I know it might be overkill configuring SS manually but I'm porting code from arduino and it is done like that over there.
    The CR95HF SPI works in 3 steps:
    1. send command
    2. poll with 0x03 until SPI return bit 4 to 1
    3. send command 0x02 to read
    The corresponding arduino code of step 1 and 2 is:
    // step 1 send the command
      digitalWrite(SSPin, LOW);
      SPI.transfer(0x00);  // SPI control byte to send command to CR95HF
      SPI.transfer(0x02);  // Set protocol command
      SPI.transfer(0x02);  // length of data to follow
      SPI.transfer(0x01);  // code for ISO/IEC 15693
      SPI.transfer(0x0D);  // Wait for SOF, 10% modulation, append CRC
      digitalWrite(SSPin, HIGH);
      delay(1);
    // step 2, poll for data ready
      while(RXBuffer[0] != 8)
        RXBuffer[0] = SPI.transfer(0x03);  // Write 3 until
        RXBuffer[0] = RXBuffer[0] & 0x08;  // bit 3 is set
      delay(1);
    So my ported code looks like this:
    uint8_t invcommand[5] = {0x00, 0x02, 0x02, 0x01,0x0D};
    nrf_gpio_pin_clear(SPI_SS_PIN);
    APP_ERROR_CHECK(nrf_drv_spi_transfer(&m_spi_master_0, &invcommand, 5, m_rx_buf, 5));
      __WFE();
    nrf_delay_ms(1);
    while(m_rx_buf[0] != 8) {
      m_tx_buf[0] = 0x03;
      APP_ERROR_CHECK(nrf_drv_spi_transfer(&m_spi_master_0, m_tx_buf, 1, m_rx_buf, 1));
        __WFE();
      m_rx_buf[0] = m_rx_buf[0] & 0x08;
    nrf_delay_ms(1);
    But it never gets out of the STEP 2 while loop and the SPI keeps returning 0x06
    I'm hoping to get my hands on a logic analyser and see how the signals on arduino vs DK52 look like.
    As for the sdk_config.h SPI data:
    NRFX_SPIM_ENABLED 1
    NRFX_SPI_ENABLED 1
    SPI_ENABLED 1
    SPI0_ENABLED 1
    SPI0_USE_EASY_DMA 1
  • Hi I mistakenly replied to PaulP but maybe you can help me as well :) . Please see bottom most reply. Thanks a lot!
  • Please post your question in a new thread. You can link to this question and say it is related, but answering in this thread will make it harder for other users to find the information if they experience similar issues.
