Writing OOB Pin to softdevice
Theoretically, if I were to expose a GATT service to let a central write a 128 bit PIN to my characteristic, would I then be able to persist this PIN somewhere in the softdevice so that all other services could starting using OOB as their security level? If so, where? What other settings need to change to support OOB once this is done?
Edit (Jul-1-14): As suggested below, I should throw in that I'm also trying to validate the demand for a way to deliver an OOB PIN to an SoC. (@Ulrich - Thanks for the tip)
  • Could you expand a bit on the use-case for this? Do you have a device that only support OOB pairing or something?
    1. If you write a static passkey over a connection established by a lesser security level, this passkey will only be as secure as the channel you sent it on (theoretically).
    2. The Bluetooth spec does not distinguish MITM and OOB (aka. "Authenticated Pairing") when it comes to security modes, so it is not currently possible to automatically (i.e. in the stack) deny peers that have paired with MITM access to the attributes protected with Security Mode 1 - Level 3. You can however fail any pairings where the peer does not set the OOB flag, or use read/write authorization and application-based security to look-up if a given bond was created with OOB or not.
    When that is said, very few central devices actually support OOB at the time being. It is meant to be used with actual out-of-band technologies like NFC or USB, as the input sequence is quite bothersome to type in on both devices. Both the S110 and S120 support OOB however, so your theoretical scheme would work, but it might not be as secure as you expected.
  • Thank you for your well thought out answer. I understand what you are saying about PIN sharing being as good as its weakest link. I am trying to see if there would be a market for a BLE chip which uses USB to accept an OOB pin. The lack of centrals supporting OOB is a bit of a chicken/egg problem for which I don't have any solution.
    For now, I wrote a 128bit key using a ECDH key exchange GATT service. Then I added the ble_app_hrs service and an open source AES implementation on to my ECDH service to encrypt heart rate information. I have this entire service stack sharing secret keys, encrypting heart rate information, and streaming this encrypted info to a tiny iPhone app I wrote.
    Since my service successfully shares private keys using ECDH, maybe OOB key exchange can be solved somehow. Any thoughts?
    ECDH: github.com/.../nano-ecc AES: github.com/.../tiny-AES128-C
  • I'm not cryptographer, but that certainly sounds much safer than sending the OOB key in the plain :)
    You are right in that OOB central support is the main road bump to accomplish things with less application responsibility, and I can only cross my fingers and hope we will see a solution for that soon.
    For now, it is possible to add read and write authorization to all of your attributes and add an encryption/decryption layer that these values get filtered through before being sent/written - and which initiates the ECDH key exchange if it has not yet been performed. I don't think there are any adopted services for encryption yet, so you would have to control both sides in all of your applications to pull this off.
  • When you said "that certainly sounds much safer," were you referring to the USB option or the option of using ECDH for 128 bit key exchange?
    Yes, you are right that I will have to control both sides of the exchange. I wonder how I can validate the idea some more to see if a startup would be interested in using such an encryption service.
  • Both are safer, but the USB option would be the safest. For the last question I really don't know, but I have seen a few posts asking about how to improve security, so there are interested parties. You should add that to the initial question so it is easier to get the responses you need.
