Hello
I noticed that since S132 v3.x.x we can configure the MTU. Does all the posts referring to long writes in this forum apply to the situation before this feature ?
thanks
Hello
thanks
If the value to be written is <= (ATT_MTU - 3) then you do not need a long write, but can perform a regular ATT Write Request/Command.
What were you using the long write for?
for sending more than 20 bytes to the peripheral. isn't it what means "long" ?
Ok. I just wanted to check. You don't need long writes to send more than 20 bytes to the peripheral, but it is one way of doing it. You need long writes to write to the part of characteristic values that are longer than the ATT MTU, and if you want to do a write with an offset.
Could you elaborate a bit on what your question is? Which post are you referring to? Which situation?
I dont know this:
but concerning this:
->I dont understand when this case can happen if you are able to augment the MTU. is there a MTU max ? if yes why isn't it the norm instead of 23 bytes ?
