I want to use Non-Resolvable Private Address for nrfmesh packet. (every mesh packet is different address)
How to do?
Currently every mesh node has different Bluetooth address when advertising and they are random static address.
Mesh protocol doesn't care about this address. It's only looking for packets on physical address (which is the BEARER_ACCESS_ADDR_DEFAULT = 0x8E89BED6).
Could you let me know why you want Non-Resolvable Private Address ?
Yes, but there isn't a big different between non-resolvable private address (except for a few requirement bits to tell the type of the address).
But if you want to use your own defined address, you can modify set_default_advertiser_configuration() in advertiser.c to set your address.
