1: (276) LaunchOptions<LocalLaunchOptions xmlns='schemas.microsoft.com/.../2014'
1: (294) LaunchOptions ExePath='/home/f/Projects/area51/myapp/BUILD/myapp.elf'
1: (294) LaunchOptions WorkingDirectory='/home/f/Projects/area51/myapp'
1: (294) LaunchOptions ExeArguments=''
1: (294) LaunchOptions MIMode='gdb'
1: (294) LaunchOptions MIDebuggerPath='/usr/bin/arm-none-eabi-gdb'
1: (294) LaunchOptions WaitDynamicLibLoad='false'
1: (294) LaunchOptions DebugServer='openocd'
1: (294) LaunchOptions DebugServerArgs='-f board/nordic_nrf52_dk.cfg -c "init" '
1: (294) LaunchOptions ServerStarted='GDB\ server\ started'
1: (294) LaunchOptions FilterStderr='true'
1: (294) LaunchOptions ServerLaunchTimeout='20000'
1: (294) LaunchOptions>
1: (294) LaunchOptions <SetupCommands>
1: (294) LaunchOptions <Command IgnoreFailures='false' Description='connect to target'>-target-select remote localhost:3333</Command>
1: (294) LaunchOptions <Command IgnoreFailures='false' Description='load file'>-file-exec-and-symbols /home/f/Projects/area51/myapp/BUILD/myapp.elf</Command>
1: (294) LaunchOptions <Command IgnoreFailures='false' Description=''>-interpreter-exec console "monitor endian little"</Command>
1: (294) LaunchOptions <Command IgnoreFailures='false' Description=''>-interpreter-exec console "monitor reset"</Command>
1: (294) LaunchOptions <Command IgnoreFailures='false' Description=''>-interpreter-exec console "monitor halt"</Command>
1: (294) LaunchOptions <Command IgnoreFailures='false' Description=''>-interpreter-exec console "monitor arm semihosting enable"</Command>
1: (294) LaunchOptions <Command IgnoreFailures='false' Description='flash target'>-target-download</Command>
1: (294) LaunchOptions </SetupCommands>
1: (294) LaunchOptions</LocalLaunchOptions>
1: (390) Starting: "openocd" -f board/nordic_nrf52_dk.cfg -c "init"
1: (20406) <-logout
C disconnect: {"restart":false}
"version": "0.2.0",
"configurations": [
"name": "C++ Launch",
"type": "cppdbg",
"request": "launch",
"program": "${workspaceRoot}/BUILD/${workspaceRootFolderName}.elf",
"args": [],
"stopAtEntry": true,
"cwd": "${workspaceRoot}",
"environment": [],
"externalConsole": false,
"debugServerArgs": "",
"serverLaunchTimeout": 20000,
"filterStderr": true,
"filterStdout": false,
"serverStarted": "GDB\\ server\\ started",
"preLaunchTask": "make",
"setupCommands": [
{ "text": "-target-select remote localhost:3333", "description": "connect to target", "ignoreFailures": false },
{ "text": "-file-exec-and-symbols ${workspaceRoot}/BUILD/${workspaceRootFolderName}.elf", "description": "load file", "ignoreFailures": false},
{ "text": "-interpreter-exec console \"monitor endian little\"", "ignoreFailures": false },
{ "text": "-interpreter-exec console \"monitor reset\"", "ignoreFailures": false },
{ "text": "-interpreter-exec console \"monitor halt\"", "ignoreFailures": false },
{ "text": "-interpreter-exec console \"monitor arm semihosting enable\"", "ignoreFailures": false },
{ "text": "-target-download", "description": "flash target", "ignoreFailures": false }
"logging": {
"moduleLoad": true,
"trace": true,
"engineLogging": true,
"programOutput": true,
"exceptions": true
"linux": {
"MIMode": "gdb",
"MIDebuggerPath": "/usr/bin/arm-none-eabi-gdb",
//"debugServerPath": "pyocd-gdbserver",
//"debugServerArgs": " --port 3333 --target nrf52 --frequency 4000"
"debugServerPath": "openocd",
"debugServerArgs": "-f board/nordic_nrf52_dk.cfg -c \"init\" "
which always gives me the error that the debug server failed to launch, but..
Open On-Chip Debugger 0.10.0
Licensed under GNU GPL v2
For bug reports, read
openocd.org/.../bugs.html
adapter speed: 10000 kHz
cortex_m reset_config sysresetreq
Info : No device selected, using first device.
Info : J-Trace Cortex-M Rev.3 compiled Nov 23 2017 16:43:50
Info : Hardware version: 3.10
Info : VTarget = 3.300 V
Info : clock speed 10000 kHz
Info : SWD DPIDR 0x2ba01477
Info : nrf52.cpu: hardware has 6 breakpoints, 4 watchpoints
// this is blocking input
works as expected (as far as I can tell).
What configuration is missing? What is the issue.
I am using a j-Trace from Segger.
The initial export was done with mbed export -i vscode_gcc_arm -m NRF52_DK --profile mbed-os/tools/profiles/debug.json
openocd
yields 0.10.0
I am not tied to openocd
, but neither does the pyocd-gdbserver
work:
1: (140) LaunchOptions<LocalLaunchOptions xmlns='schemas.microsoft.com/.../2014'
1: (148) LaunchOptions ExePath='/home/f/Projects/area51/myapp/BUILD/myapp.elf'
1: (148) LaunchOptions WorkingDirectory='/home/f/Projects/area51/myapp'
1: (148) LaunchOptions ExeArguments=''
1: (148) LaunchOptions MIMode='gdb'
1: (148) LaunchOptions MIDebuggerPath='/usr/bin/arm-none-eabi-gdb'
1: (148) LaunchOptions WaitDynamicLibLoad='false'
1: (148) LaunchOptions DebugServer='pyocd-gdbserver'
1: (148) LaunchOptions DebugServerArgs=''
1: (148) LaunchOptions ServerStarted='GDB\ server\ started'
1: (148) LaunchOptions FilterStderr='true'
1: (148) LaunchOptions ServerLaunchTimeout='20000'
1: (148) LaunchOptions>
1: (148) LaunchOptions <SetupCommands>
1: (148) LaunchOptions <Command IgnoreFailures='false' Description='connect to target'>-target-select remote localhost:3333</Command>
1: (148) LaunchOptions <Command IgnoreFailures='false' Description='load file'>-file-exec-and-symbols /home/f/Projects/area51/myapp/BUILD/myapp.elf</Command>
1: (148) LaunchOptions <Command IgnoreFailures='false' Description=''>-interpreter-exec console "monitor endian little"</Command>
1: (148) LaunchOptions <Command IgnoreFailures='false' Description=''>-interpreter-exec console "monitor reset"</Command>
1: (148) LaunchOptions <Command IgnoreFailures='false' Description=''>-interpreter-exec console "monitor halt"</Command>
1: (148) LaunchOptions <Command IgnoreFailures='false' Description=''>-interpreter-exec console "monitor arm semihosting enable"</Command>
1: (149) LaunchOptions <Command IgnoreFailures='false' Description='flash target'>-target-download</Command>
1: (149) LaunchOptions </SetupCommands>
1: (149) LaunchOptions</LocalLaunchOptions>
1: (200) Starting: "pyocd-gdbserver"
1: (20208) <-logout
pyocd-gdbserver --version
yields 0.8.0
