I am trying to use a dht sensor and arch ble device to display temperature on the console. But when I flash the program on to the board, I cant see the output on the console. What should I do... PS: This is the first time I am using a BLE board
You need to describe how do you test, what program you made, what you expect to see on the console. How do you communicate with the dht sensor ?
@hung Bui thanks for replying...I imported the program from 'mbed compile which has the highest number of imports. And I connected the sensor to the arch ble board using grove connector.
I would suggest to ask the question on mbed forum.
When you ask a question, you should give as much as possible information about the case. Also you need to do some debugging and provide those information. We can't help you with what you provided.
