Hello, I am using sdk12.2 and nrf52. I want to send more than 8 packets of data to nrf app. How can I do that? My code snippet is as follows:
enter code here
void data_send(void) { uint32_t err_code; //uint8_t sensor_data[10]; uint8_t sensor_data[20]; uint8_t dl_buffer[10000]; // uint16_t sensor_data[10]; uint16_t j=0; fds_flash_record_t flash_record; memset(sensor_data, 0, 20); memset(dl_buffer, 0, 6000); fds_record_desc_t record_desc; fds_find_token_t ftok ={0};//Important, make sure you zero init the ftok token uint8_t *data; // uint16_t *data;
// Loop until all records with the given key and file ID have been found.
// while (fds_record_find_in_file(file_read,&record_desc, &ftok) == FDS_SUCCESS)
while (fds_record_find(file_read,rec_read,&record_desc, &ftok) == FDS_SUCCESS)
err_code = fds_record_open(&record_desc, &flash_record);
data = (uint8_t *) flash_record.p_data;
for (uint8_t i=0;i<flash_record.p_header->tl.length_words;i++)
NRF_LOG_INFO("Find Data: %d\r\n",data[i]);
dl_buffer[j] = data[i];
NRF_LOG_INFO("dl_buffer %d\r\n ",dl_buffer[j]);
NRF_LOG_INFO("i %d\r\n ",i);
NRF_LOG_INFO("j %d\r\n ",j);
j++;
// Access the record through the flash_record structure.
// Close the record when done.
err_code = fds_record_close(&record_desc);
for (uint8_t i=0,k = 0;k<j;i++,k++)
sensor_data[i] = dl_buffer[k];
NRF_LOG_INFO("sensor_data %d\r\n ",sensor_data[i]);
//if (i == 18)
if (/*((j < 18 ) && j > 6) || */(i == 18))
//nrf_delay_ms(200);
err_code = send_notification(sensor_data);
if (err_code != NRF_SUCCESS &&
err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
err_code != NRF_ERROR_INVALID_STATE &&
err_code != (NRF_ERROR_STK_BASE_NUM+NRF_ERROR_NO_MEM))
NRF_LOG_INFO("Send_notif_error: %d\r\n",err_code);
//memset(sensor_data, 0, 20);
i = 0;
