GPIOTE power problem IC revision 3
Hello everyone,
My IC description: nRF51822 QFAAHO, which belongs to IC revision 3 and, as the PANv3.0 says, "1V2 + HFCLKarerequested always when the GPIOTE task is configured." is a fixed anomaly.
My nRF should do the next: I have a button that wakes up the device and, in the case there is a phone connected, the device will send a '1', otherwise, pressing the button will reset the device.
My problem is: when I'm using GPIOTE (gpiote_init() is not commented), the device consumes around 0.922 mA. On the other hand, when I comment gpiote_init() the consumption goes to 0.033 mA.
My question is: Can someone check what am I doing wrong or comment a solved thread with same/similar issue??
This is my code:
int main(void){
    bool     erase_bonds = true;
    // Initialize.
    timers_init();
    gpiote_init();
    ble_stack_init();
    peer_manager_init(erase_bonds);
    gap_params_init();
    advertising_init();
    gatt_init();
    services_init();
    conn_params_init();
    application_timers_start();
    advertising_start();
    for (;;){
        power_manage();
void gpiote_init(void){
    if(!nrf_drv_gpiote_is_init()){
        nrf_drv_gpiote_init();
    nrf_drv_gpiote_in_config_t config = GPIOTE_CONFIG_IN_SENSE_LOTOHI(true);
    config.pull = NRF_GPIO_PIN_PULLDOWN;
    nrf_drv_gpiote_in_init(BUTTON, &config, gpio_handler);
    nrf_drv_gpiote_in_event_enable(BUTTON, true);
    return;
static void gpio_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action){
      if(checkConnection(&m_hrs) == 1){
        //  NRF_LOG_INFO("ShortPress: Connected!\r\n");
          //err_code =
          ble_hrs_heart_rate_measurement_send(&m_hrs);
      }else{
          NVIC_SystemReset();
