APP_ERROR_CHECK outside main while(1) loop
I want to check if some errors happened during the initialization before entering while(1) loop in the main. I am using nrf_CLI in my application (SDK 14.2.0 and S140 on nRF52840).
So my main function looks like
void main( void )
    sys_hw_init();
    log_init();
    cli_init();
    cli_start();
    err = System_Init();
    APP_ERROR_CHECK(err);
    NRF_LOG_INFO("Starting peripheral device...");
    while(1)
        cli_process();
            wait_for_event();
When I use APP_ERROR_CHECK outside the main loop and there is an error, I don't see anything printed on the serial terminal (err is non-zero and not equal to NRF_SUCCESS). But if run time error occurs after application enters the main loop, then I see APP_ERROR_CHECK function normally without issues.
What could be wrong in the usage? It gets stuck inside the macro NRF_LOG_ERROR in the app_error_fault_handler routine , case NRF_FAULT_ID_SDK_ASSERT.
  • Yes. I am checking for errors inside cli_init and cli_start. There are no errors and it returns from those two functions. I am using UART as backend.
    void CLI_Init(void)
        nrf_drv_uart_config_t uart_config = NRF_DRV_UART_DEFAULT_CONFIG;
        uart_config.pseltxd = TX_PIN_NUMBER;
        uart_config.pselrxd = RX_PIN_NUMBER;
        uart_config.hwfc    = NRF_UART_HWFC_DISABLED;
        ret_code_t err_code = nrf_cli_init(&m_cli_uart, &uart_config, true, true, NRF_LOG_SEVERITY_INFO);
    void CLI_Start(void)
        ret_code_t err_code =  nrf_cli_start(&m_cli_uart);
    void CLI_Init(void)
