Target - NRF52832 populated on a custom PCB using SDK 14.0.0 and s132 5.0
Background - end device will be used to send logged IMU data to the cloud via a smart device, 2-3mB expected to be sent at a time
Looking for a bit of help to increase the throughput using an IOS master (or really any device, but I'm currently using an iphoneSE). I'm running a lightly modified version of the peripheral ble_app_uart example - no UART functionality is now used, I am simply sending dummy data to evaluate throughput. Data length is successfully negotiated to 182 bytes. Connection interval is confirmed at 30ms. I am sending 182 byte packets (using ble_nus_string_send) upon every receipt of BLE_GATTS_EVT_HVN_TX_COMPLETE. Reviewing a log of packets received on the iphone (using lightBlue), I am predominately seeing a packet sent every ~30ms, with occasional packets separated by a few milliseconds. This results in a functional throughput of about 7kB/s.
I expected (hoped) that I would see multiple packets received within that 30ms window.
My questions:
I've read that the connection interval can be dropped to 15ms with iOS devices - can you provide guidance with regards to the best way to complete this. I attempted to negotiate after a connection was made (using ble_conn_params_change_conn_params), but the 30ms interval was maintained. I understand that it may be better to stick with a longer connection interval given the bigger packet size (and assuming I can get to 6 or 7 packets per interval), but if I am limited to fewer packets per interval, a shorter connection interval would be better.
What might be limiting me to 1, occasionally 2, packets per interval? Should I be attempting to send more frequently than waiting for BLE_GATTS_EVT_HVN_TX_COMPLETE?
Any help appreciated, I have searched, and turned up a number of good threads that have helped me get this far, but I think I've hit a bit of a wall.
-Chris
