I cannot find "Master Control Panel" for MacOS, can I test with iOS or MacOS itself? None of them seems to able to discover my PCA10001 running S110+nAN36 LED.
Thank you!
Richard
Thank you!
Richard
Found an Android app play.google.com/.../details
But app found no device. What could have went wrong?
The JLink GDB output is:
SEGGER J-Link GDB Server V4.80e Command Line Version
JLinkARM.dll V4.80e (DLL compiled Jan 31 2014 18:13:40)
-----GDB Server start settings----- GDBInit file: none GDB Server Listening port: 2331 SWO raw output listening port: 2332 Terminal I/O port: 2333 Accept remote connection: localhost only Generate logfile: off Verify download: on Init regs on start: on Silent mode: off Single run mode: on ------J-Link related settings------ J-Link script: none Target interface: SWD Host interface: USB Target endian: little Target interface speed: 1000kHz
Connecting to J-Link... J-Link is connected. Firmware: J-Link OB-SAM3U128 V1 compiled Dec 11 2013 20:20:11 Hardware: V1.00 S/N: 480110970 Checking target voltage... Target voltage: 3.30 V Listening on TCP/IP port 2331 Connecting to target...Co
Found that the flash was erroneous. Rebuilt with github.com/.../nrf51-pure-gcc-setup and it all good now.
You can use the sniffer from RK under OS X to sniff for devices. Just look in the blog for it: Link to Sniffer
Other examples with accompanying iOS code can be found here embeddedsoftdev.blogspot.ca/.../ehal-nrf51.html
