Enforce order of connection to centrals
I have peripheral BLE device which can have several centrals in its whitelist. It should be able to connect to central with higher priority first, for example: device have 3 centrals in whitelist with A having highest priority, B second highest and C lowest, when device is powered up and all centrals available it should always connect to A, if A is not available - to B and so on.
So my questions is:
  1. Can it be implemented on nrf52?
  2. If 1 is doable: Can it be done not to slow(compared to normal connection time)? Thanks!
  • Another option could be to advertise with A, B and C in the whitelist.
    If A connects first, you stop advertising.
    If B connects first you continue to advertise with A in whitelist, and then if A connects you disconnect B and stop advertising.
    If C connects first you continue to advertise, if B then connects you disconnect C and continue to advertise with A in the whitelist and so on..., and if A connects you disconnect C and stop advertising.
