I am trying to write and update a record in flash but not receiving event callbacks FDS_EVT_WRITE and FDS_EVT_UPDATE. I found that i need to add the following code in my main.c
static void sys_evt_dispatch(uint32_t sys_evt)
// Dispatch the system event to the fstorage module, where it will be
// dispatched to the Flash Data Storage (FDS) module.
fs_sys_event_handler(sys_evt);
err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
Am unable to use this in SDK 14.1.0 . How do i write and enable softdevice soc event handler in this SDK version.
Thanks in advance.
