nrf52840 MPU9250 Magnetometer Reading
Hello, I am using nrf52840 PDK, sdk 13.0.0. I managed to read accel, gyro data from the MPU9250 using MPU library based on this example. However, I got magnetometer reading 0. I've checked this question and this question. Here is the code how I setup the MPU:
void mpu_setup(void)
	printf("\r\nMPU setup start... \r\n");
    ret_code_t ret_code;
    // Initiate MPU driver
    ret_code = mpu_init();
	printf("\r\nMPU init complete! \r\n");
    APP_ERROR_CHECK(ret_code); // Check for errors in return value
    // Setup and configure the MPU with intial values
    mpu_config_t p_mpu_config = MPU_DEFAULT_CONFIG(); // Load default values
    p_mpu_config.smplrt_div = 19;   // Change sampelrate. Sample Rate = Gyroscope Output Rate / (1 + SMPLRT_DIV). 19 gives a sample rate of 50Hz
    p_mpu_config.accel_config.afs_sel = AFS_16G; // Set accelerometer full scale range
    p_mpu_config.gyro_config.fs_sel = GFS_1000DPS; //Set gyroscope full scale range
    ret_code = mpu_config(&p_mpu_config); // Configure the MPU with above values
void magn_setup()
	//Enable bypass mode
	mpu_int_pin_cfg_t bypass_config;
	bypass_config.i2c_bypass_en = 1;
	ret_code = mpu_int_cfg_pin(&bypass_config); // Set bypass mode
	// Setup and configure the MPU Magnetometer
	mpu_magn_config_t p_mpu_magn_config;
	p_mpu_magn_config.resolution = OUTPUT_RESOLUTION_16bit; // Set output resolution
	p_mpu_magn_config.mode = CONTINUOUS_MEASUREMENT_100Hz_MODE;	//Set measurement mode
	ret_code = mpu_magnetometer_init(&p_mpu_magn_config);
The full project can be found here. Need some help. Many thanks.
Update 22 Jan 2018:
Code added to magn_setup:
    ret_code = nrf_drv_mpu_write_magnetometer_register(0x0A, 6);	//writing to the control register
	uint8_t TempReading;
	ret_code = nrf_drv_mpu_read_magnetometer_registers(0x00, &TempReading, 8);
	printf("Device ID: %d \n", TempReading);
	ret_code = nrf_drv_mpu_read_magnetometer_registers(0x0A, &TempReading, 8);
	printf("Vaule read from control register: %d \n", TempReading);
Result observed by Termite:
Test1: MPU twi communication
MPU setup start...
MPU init complete!
MPU setup complete!
Device ID: 72
Vaule read from control register: 6
Accel Data: X: 000732 ; Y: -00111 ; Z: -02000 ;
Gyro Data: X: -00010 ; Y: 000030 ; Z: 000021 ;
Magn Data: X: 000000 ; Y: 000000 ; Z: 000000 ;
    It seems like I forgot to add functions for actually starting the magnetometer. Please refer to the MPU 9250 register map and look at Chapter 5.8, CNTL1: Control 1. Write e.g. 6 to this register to start continuous measurement.
    A quick and dirty way to do it is to include nrf_drv_mpu.h in main.c and call nrf_drv_mpu_write_magnetometer_register(0x0A, 6) when you initialize your MPU.
    Note to MPU 9150 users: There is no continuous mode on the MPU 9150 so a single measurement has to be started before every read. Note that it seems like it takes ~5ms from the measurement is started until valid data is ready to be read.
  • What do you mean by "the magnetometer goes on my MPU9250"? I don't know if it is broken. At least it is responding and not completely dead. I tested with one of these, by the way.
  • Hello Martin, I've solved this problem, the code is correct, the error is caused by the design flaw of the MPU evaluation board. But I met another problem, I tried to modify your mpu_read_register function, but it seems cannot be executed properly, here is the function, could you pls have a look?
    uint32_t mpu_twi_read(uint8_t slave_addr,uint8_t reg_addr,uint32_t length,uint8_t *data)
    	  uint32_t err_code;
    		uint32_t timeout = MPU_TWI_TIMEOUT;
    	  err_code = nrf_drv_twi_tx(&m_twi_instance, slave_addr, &reg_addr, 1, false);
    		if(err_code != NRF_SUCCESS) return err_code;
        while((!twi_tx_done) && --timeout);
        if(!timeout) return NRF_ERROR_TIMEOUT;
        twi_tx_done = false;
    	  err_code = nrf_drv_twi_rx(&m_twi_instance, slave_addr, data, length);
        while((!twi_rx_done) && --timeout);
        twi_rx_done = false;
    		return err_code;
    So what happens exactly?
  • I wrote another c file including an h file, the function above is defined in there. But when I call this function in the main, the program gets stuck and the code after the calling doesn't execute. I called NRF_DRV_TWI_INSTANCE(0) to create a twi instance in my c file, as I kept your twi instance at the same time. Will having two same twi instances cause the error?
  • Yes. Why do you need to call it twice? Unless you need two sepparate TWI busses, then you only need one instance. You can pass a pointer to this instance to your various C files which is usually how it is done in our SDK drivers.
