SDK14.2 DFU power cycle issue
Situation: Trying to upgrade previous versions of the SD and BL (V3.0.0) to (V5.0.0) Problem: device power cycles after a new application is flashed to the device into the V5.0.0 SD and BL.
Steps:
  1. Take target device, including dev board, and program SD3.0.0 and V3.0 buttonless bootloader
  2. DFU an App appropriate for SDV3.0.0 and run it.
  3. DFU the new SD and BL (V5.0.0) package to the device
  4. DFU an App appropriate for SDV5.0.0 and run it
Result of performing all 4 steps is that the device keeps power cycling. If you skip step 2, the procedure works and the device functions as desired.
I am guessing that there is some internal register that is written to during the DFU process in step 2, and that this register is not being updated to accommodate the position changes due to the larger SD.
Is there a work around?
