SDK 14.2: NRF_LOG prefix is garbage
Hello all I am trying to get out some debug messages from my custom Firmware (and board) but the log looks like this:
<info> µ“°8$M­ø@ñ¨ó¹)F¨: NRF_LOG initialized
I am fiddling around in SDK-config.h for a while now, but can't find a solution to this. Any suggestions what could be causing this? The project previously used the RttDebugPrintDebug(), which I deactivated just for now to see if this messes up things but this didn't change anything...
The relevant parts of my main.cpp look like this:
#ifdef __cplusplus
extern "C" {
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include <sdk_config.h>
#define NRF_LOG_MODULE_NAME main
#include "nrf_log.h"
NRF_LOG_MODULE_REGISTER();
#include "nrf_log_ctrl.h"
#ifdef __cplusplus
int main(void) {
    (void) NRF_LOG_INIT(NULL);
    NRF_LOG_INFO("NRF_LOG initialized\r\n");
    while(1) {
        NRF_LOG_PROCESS();
There are lot's of other headers included, which I ommited for readability. I guess they won't mess up things, because I don't use any of the functions of my project while debugging this issue as you can see in my main().
And here you can see the relevant content of my app_config.h
#define NRF_LOG_ENABLED 1
#if (NRF_LOG_ENABLED == 1)
    #define NRF_FPRINTF_ENABLED 			1
    #define NRF_BALLOC_ENABLED 				1
    #define NRF_LOG_BACKEND_RTT_ENABLED		1
    #define NRF_LOG_BACKEND_UART_ENABLED	0
    #define NRF_LOG_BACKEND_RTT_TEMP_BUFFER_SIZE 	64
    #define NRF_LOG_BACKEND_MAX_STRING_LENGTH		32
    #define NRF_LOG_BACKEND_UART_BAUDRATE 			30801920
    #define NRF_LOG_USES_COLORS 			1
    #define NRF_LOG_ERROR_COLOR				2
    #define NRF_LOG_WARNING_COLOR			4
    #define NRF_LOG_COLOR_DEFAULT			3
    #define NRF_LOG_DEFAULT_LEVEL 				4
    #define NRF_LOG_DEFERRED					1
    #define NRF_LOG_BUFSIZE						1024
    #define NRF_LOG_USES_TIMESTAMP				0
    #define NRF_LOG_ALLOW_OVERFLOW				1
#endif	// NRF_LOG_ENABLED
#define SEGGER_RTT_CONFIG_BUFFER_SIZE_UP		2048
#define SEGGER_RTT_CONFIG_BUFFER_SIZE_DOWN 		16
#define SEGGER_RTT_CONFIG_DEFAULT_MODE 			0
#define NRF_LOG_FILTERS_ENABLED 				0
Any suggestions how to resolve this?
Kind regards Karl
  • I have to thank you @Jørgen Holmefjord because while trying to create this minimum working example I stumbled upon the solution. Turns out, there was an error in my linker script. I am not sure why it makes a difference, but with this setting ind the linker script everything works just fine now. Here is the wrong part
    .log_dynamic_data :
        PROVIDE(__start_log_dynamic_data = .);
        KEEP(*(.log_const_data))  /*THIS LINE IS WRONG*/
        PROVIDE(__stop_log_dynamic_data = .);
    } > RAM
    .log_const_data :
        PROVIDE(__start_log_const_data = .);
        PROVIDE(__stop_log_const_data = .);
    } > FLASH
    I had to change it to:
    .log_dynamic_data :
        KEEP(*(SORT(.log_dynamic_data*)))  /*CORRECT*/
    } > RAM
    .log_const_data :
        KEEP(*(SORT(.log_const_data*)))  /*CORRECT*/
    } > FLASH
    I'll attach my complete linker script as a reference here: gcc_nrf52.ld
    And also my akefile from the minimum working example: Makefile
    And here my main.cpp from the minimum working example: main.cpp
    And here the sdk_config.h: sdk_config.h
    Thank you for your input, I hope this helps some people from loosing their hair :)
  • I ran into this problem as well. It caused nrf_log_init() to overwrite the .bss section--very bad.
    There are 431 .ld files in SDK14.2; I did a random sampling and found the error in about 1/3 of them.
  • Do you mean that this issue is present in the SDK examples? I can't find this issue in any of the linker files in SDK 14.2. Could you give an example of a file that have this issue?
