NRF24L01 won't power up
I'm trying to set PWR_UP bit to 1 for the device to go into standby-I mode using STM32F103RBT6 and HAL libraries.
I send (0x20 | 0x00) command (write_reg | config reg) followed by 0x02(PWR_UP = 1) data. Then i wait for 2ms and read the config register. It gives me back the default reset value and ofc PWR_UP bit has not been changed to 1. Status register shows 0x0E value, which should be the correct reset value.
I even used logic analyser and the data is being sent correctly. What am I doing wrong?
Thanks for your help.!
static void MX_SPI1_Init(void)
  /* SPI1 parameter configuration*/
  hspi1.Instance = SPI1;
  hspi1.Init.Mode = SPI_MODE_MASTER;
  hspi1.Init.Direction = SPI_DIRECTION_2LINES;
  hspi1.Init.DataSize = SPI_DATASIZE_8BIT;
  hspi1.Init.CLKPolarity = SPI_POLARITY_HIGH;
  hspi1.Init.CLKPhase = SPI_PHASE_1EDGE;
  hspi1.Init.NSS = SPI_NSS_SOFT;
  hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_8;
  hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB;
  hspi1.Init.TIMode = SPI_TIMODE_DISABLE;
  hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
  hspi1.Init.CRCPolynomial = 10;
  if (HAL_SPI_Init(&hspi1) != HAL_OK)
    _Error_Handler(__FILE__, __LINE__);
void nrf_Set_Handle(SPI_HandleTypeDef *hspi1, SPI_HandleTypeDef *hspi2) {
	handle1 = hspi1;
	handle2 = hspi2;
void nrf_powerUp(void){				// FUNCTION PUTS NRF24L01+ FROM POWER DOWN TO STANDBY I MODE
	uint8_t cmd;
	uint8_t val;
	HAL_GPIO_WritePin(NRF_CSN, GPIO_PIN_RESET);
	HAL_GPIO_WritePin(NRF_CE, GPIO_PIN_RESET);
	cmd = NRF_CMD_W_REGISTER|NRF_CONFIG;
	val = 0x02;
	HAL_SPI_Transmit(handle1,&cmd,1,0);
	HAL_SPI_Transmit(handle1,&val,1,0);
	HAL_GPIO_WritePin(NRF_CSN, GPIO_PIN_SET);
	HAL_Delay(2);
void nrf_read_register(void){
	uint8_t cmd;
	uint8_t dummy = 0x00;
	cmd = NRF_CMD_R_REGISTER|NRF_CONFIG;
	HAL_SPI_Transmit(handle1,&dummy,1,0);
	HAL_Delay(0.001);
