Having issues with back to back printfs across the UART.
I am using the "Nordic Uart Service", example to create a simple serial console which allows a user to change settings such as tx power, advertising intervals so that different combinations of these settings can be characterized. As such a simple text menu is printed out. The issue is that after I exceed a certain amount of characters the output no longer appears.
Is there a limit to the number of characters I can transmit in a given time, currently I am flushing stdout in order to force all the output to the terminal screen.
The device isn't hung up, at this time further print operations work, the only relation is that the prints are back to back for list of commands.
  • Don't quite understand your setup here. Is it a simple "PC <-- uart --> nRF52" connection or a more elaborate "PC <-- uart--> BLE dongle <-- BLE --> nRF52-to-be-configured" ?
  • PC <--> UART <--> pca10056 <--> BLE(NUS) <--> custom board(nrf52840). The printfs are only running on the pca10056 and simply present the options allowed. Essentially using the pca10056 as a dongle.
  • I have a similar set up to configure my custom board(nRF52832) also, although mine is less elaborate and the user on the PC end simply sends the AT commands and waits for ACK/NAK from the custsom board. Now the uart between pc and the dongle is fast while the BLE between the dongle and the custom board is "slow" (well, relative to the uart) so do you have h/w flow control enabled for the uart?
  • At one point I place a 500ms delay between each consecutive print in this code to see if I was overrunning the UART. I didn't see any improvement in the behavior and removed it. I know this is a crude replacement for HW flow control, but I was just checking if it could be the issue.
  • When you write: "after I exceed a certain amount of characters the output no longer appears." after how many characters does the output no longer appear? These two links might be useful (link 1, link 2).
1 2
