I have a problem with NRF_LOG_INFO() macro - it only shows messages form main.c file but not from another .c files in project. Why this could happen?
I work in Eclipse with gcc and nRF52840
There is no such macro RTT_LOG_INFO() in the SDK. Is this something you have defined yourself, or did you mean NRF_LOG_INFO()? Is the other .c files part of your application, or is is drivers/libraries from our SDK? Note that most of the modules have logging disabled by default. Logging can be enabled using the {MODULE_NAME}_CONFIG_LOG_ENABLED, as shown in the Logger Configuration API documentation.
I mean NRF_LOG_INFO(), thanks for correction, .c files was added to Makefile and Eclipse project. Some of them was created by me, others was SDK libraries. I'll check {MODULE_NAME}_CONFIG_LOG_ENABLED macros and let you know what happen
