Problem with PWM and Timer simultaneous with WS2812B leds
I'm using nRF52832 SDK board with softdevice s132_nrf52_5.0.0 and SDK 14.2. The program compile without an error. I tested the led and timer separately and these work.
When the timer throws the timeout_handler and try to send pwm to set ws2812b leds, the program crashed.
<error> app: ERROR 3735928559 [Unknown error code] at C:\Nordic_Semi\nRF5_SDK_14
.2.0_17b948a\components\drivers_nrf\pwm\nrf_drv_pwm.c:286
when I comment the part code of to send pwm to leds, it works fine.
static void animation_timeout_handler(void * p_context)
 //set_pixel_RED(0);
 //nrf_drv_WS2812_show(); //error, send pwm to leds.
 NRF_LOG_INFO("animation_counter %d", counter_iteration);
 counter_iteration--;
 if(counter_iteration<=0){
    stop_animation_timer();
    counter_iteration = ITERATION_MAX;
I'm using app_timer.h in timer, and nrf_drv_pwm.h to pwm0.
    If you convert 3735928559 to hex value, you get the code DEADBEEF. This is typically a assert from the SoftDevice. This could happen if you are using e.g a peripheral with restricted access(The SoftDevice need e.g. TIMER0), or if you are calling a SoftDevice function from a high interrupt priority.
    Could you post the code for the nrf_drv_WS2812_show() function? If we look at line 286 in nrf_drv_pwm.c, we have this line:
    ASSERT(p_cb->state != NRF_DRV_STATE_UNINITIALIZED);
    This means that you are trying to start a nrf_drv_pwm_simple_playback(), but you have not initialized the driver with nrf_drv_pwm_init().
  • Thanks Sigurd, My mystake was that I had wrongly initialized (I had not added it) the module nrf_drv_WS2812_init(pin) in which pwm was initialized. There was no error in compile.
    void nrf_drv_WS2812_init(uint8_t pin)
    nrf_gpio_cfg_output(pin);
    nrf_gpio_pin_clear(pin);
    uint32_t err_code;
    nrf_drv_pwm_config_t const config0 =
        .output_pins =
            pin, // channel 0
            NRF_DRV_PWM_PIN_NOT_USED, // channel 1
            NRF_DRV_PWM_PIN_NOT_USED, // channel 2
            NRF_DRV_PWM_PIN_NOT_USED  // channel 3
        .irq_priority = APP_IRQ_PRIORITY_LOW,
        .base_clock   = NRF_PWM_CLK_16MHz,
        .count_mode   = NRF_PWM_MODE_UP,
        .top_value    = PERIOD_TICKS,
        .load_mode    = NRF_PWM_LOAD_COMMON,
        .step_mode    = NRF_PWM_STEP_AUTO
    err_code = nrf_drv_pwm_init(&m_pwm0, &config0, NULL);  // handler is NULL
    for(int i = 0; i < NRF_PWM_VALUES_LENGTH(m_seq_values); i++)
        m_seq_values[i] = ONE_HIGH_TICKS;
    for(int i = 0; i < RESET_ZEROS_AT_START; i++)
    m_seq_values[i] = 0x8000;
    m_seq_values[NR_OF_PIXELS * 24 + RESET_ZEROS_AT_START] = 0x8000;
    nrf_drv_pwm_simple_playback(&m_pwm0, &m_seq, 1, 0);
