micro:bit nrf51822 can not set GPIO:30 to TWI0.PSELSDA
Hello Nordic Devzone,
I have problems with twi/i2c init code on a Micro:bit, nrf51822. The accelerometer is a Freescale MMA8652FC. I use Segger Embedded Studio for ARM V3_34 64-bit.
The accelerometer works fine with codes from makecode.microbit.org or mbed.com I also checked the P19:SCL and P20:SDA pins on the edge connector with a logic analyser and they work fine.
The thumb assembly code is here. I cut the code out from a longer file.
The full code is here in a ZIP file. drive.google.com/open
@----------- code starts
gpio_regs=    0x50000000
twi0_base=    0x40003000
RXDREADY=     0x108
TXDSENT=      0x11c
PSELSCL=      0x508
PSELSDA=      0x50c
FREQENCY=     0x524
 K100=0x01980000
 K250=0x04000000
 K400=0x06680000
pin_i2c_scl=    0      @ pin 19 on edge connector
pin_i2c_sda=    30     @ pin 20 on edge connector
.macro out32 rreg,vval
 ldr r1,=\rreg
 ldr r0,=\vval
 str r0,[r1]
.endm
.macro in32 rreg
 ldr r1,=\rreg
 ldr r0,[r1]
.endm
/*         Set GPIO pins to
    input, connect input buffer,
    pull up on bit, standard '0' - disconnect '1'
    sense disabled     */
tmp1=0 | 0<<1 | 3<<2 | 6<<8 | 0<<16
 out32 gpio_regs|0x700|pin_i2c_scl<<2,tmp1
 out32 gpio_regs|0x700|pin_i2c_sda<<2,tmp1
 out32 twi0_base|RXDREADY,0
 out32 twi0_base|TXDSENT,0
 out32 twi0_base|PSELSCL,1<<pin_i2c_scl
 out32 twi0_base|PSELSDA,1<<pin_i2c_sda
 out32 twi0_base|FREQENCY,K400
@----------code ends
The problem is that I can not select GPIO:30 to TWI0.PSELSDA.
I always get "0" when I read back TWI0.PSELSDA.
 in32 twi0_base|PSELSDA
I did read the NRF51 docs and the C code for twi_init is the same.
My other codes compile and run fine so settings and defines are okay.
Thank you in advance.
Edit: Something is not clear to me. What should be written to the PSELSDA register? The GPIO pin number or the GPIO bit mask?
image description
out32 twi0_base|PSELSCL,pin_i2c_scl
or
When I write the GPIO mask (1<<0 and 1<<30) then the SCL line works, SDA line doesn't. If I write the pin # (0, 30) then nothing works.
