Having Android reconnect to a bonded peripheral without user interaction
I've read the Robin Heydon book and bits of the Core 4.0 spec and I'm still confused as to how an Android phone with my app installed is supposed to reconnect to my peripheral to which is has previously connected and bonded.
Suppose my peripheral is a device designed to detect the presence of its owner, who is always carrying their mobile phone and that phone is always switched on, but may be in standby mode. Suppose the mobile is running Android 4.4 or later.
The Android BLE API Guide is quite clear about the initial connection: doing an LE scan, connecting to the GATT server, discovering services, etc. But it says nothing about subsequent reconnections and very little about bonding in the context of LE.
In order for a connection to be established, the peripheral has to be advertising and the central has to be scanning. My peripheral is an nRF51822 and I can have it advertise at the right times, no problem there. But if the central is an Android phone, when does it scan?
Does it only scan when I programatically call startLeScan() in my app code? I don't think this is the case - I've seen a reconnection happen without that.
Is there a background process running on Android that is always scanning for devices to which it has previously bonded? That also doesn't seem to be the case, at least not reliably - reconnection happens for a few hours after I've programmatically scanned but within a day or so it's stopped, I think.
(Using the Sniffer and Wireshark is of limited use here. Since it's scanning I'm interested in, there's nothing to see on the air because a scan is just RX. There's the scan request and response to see afterwards, but I'm more interested in when Android is doing the bit before that, the RX bit.)
  • As far as i know it scans with a callback if you start startLEScan, but there is the possibility to set a flag for an auto-connect if the device is available:
    mBluetoothGatt = device.connectGatt(this, false, mGattCallback);
    The second parameter is the autoConnect parameter [1] (boolean indicating whether to automatically connect to the BLE device as soon as it becomes available). So, i guess it scans in the background without starting it (otherwise, it wouldn't be possible to auto reconnect)
    Was this your question? cheers
    [1] developer.android.com/.../bluetooth-le.html
  • Here's some interesting Javadoc from BluetoothGatt.connect() method (not the public one) in the AOSP source, which rather implies that subsequent connections are to be made programmatically:
    The autoConnect paramter determines whether to actively connect to the remote device, or rather passively scan and finalize the connection when the remote device is in range/available. Generally, the first ever connection to a device should be direct (autoConnect set to false) and subsequent connections to known devices should be invoked with the autoConnect parameter set to true.
