nrfGo Studio doesn't work with micro:bit?
Just wanted to ask: is this expected that nrfGo Studio doesn't work with the micro:bit?
Presumably this means that nrfGo Studio doesn't work with CMSIS-DAP in general?
What's the alternative?
Thanks.
  • Hi Andrew.
    No, I'm afraid it is not expected for nRFgo Studio to work with the BBC micro:bit out of the box.
    To program your micro:bit, you should be able to simply drag-and-drop your file onto the MICROBIT removable drive.
    However, you can take a look at this post from SEGGER, about how to upgrade the BBC micro:bits DAPLink to a J-link OB:
    "Upgrading to J-link enables the use of a broad range of IDEs"
    "Maintains support of HEX file Drag-and-drop"
    This might enable the micro:bit to be used with nRFgo Studio (Note that I have not tested this myself).
    More information can be found on the micro:bit website.
    Also the micro:bit developer community might be of interest, where you can take a look at this post.
    Hope that helps.
    Joakim.
