Mesh-SDK v1.0.1: Light switch demo not working correctly
I am trying to run the light switch example of the nRF5-SDK-for-Mesh-v1.0.1 on total 2 boards(1-client (own nrf52832 board) and 1-servers (dev kit nrf52832 with pca10040)). Only 1 server gets provisioned as expected.
On the client when I press the zero button on the rtt to make set simple_on_off_client_set...
The first time it goes well. From the first time the program gets stuck.
Whenever I restart the client, works the first time.
Can someone help with this problem?
Logs Client:
1st time:
<t:          0>, main.c,  441, ----- BLE Mesh Light Switch Client Demo -----
<t:          0>, nrf_mesh_sdk.c,  187, Initializing softdevice
<t:          0>, nrf_mesh_sdk.c,  122, Initializing SoftDevice...
<t:          3>, nrf_mesh_sdk.c,  131, Ram base: 0x200031B0
<t:         22>, nrf_mesh_sdk.c,  197, Initializing mesh stack
<t:        582>, nrf_mesh_sdk.c,  205, Enabling mesh stack
<t:        588>, main.c,  183, Setting up access layer and models - abcd
<t:        593>, device_state_manager.c, 1522, <>Setting dsm_init
<t:        600>, access.c,  595, <>Add flash manager success
<t:       5498>, main.c,  257, <> provisioner_wait_for_unprov
<t:     295853>, access.c,  320, <>MESH_EVENT_CB_CALLED
<t:     295857>, access.c,  324, <>NRF_MESH_EVT_MESSAGE_RECEIVED
<t:     295860>, access.c,  285, <>mesh_msg_handle
<t:     295863>, access.c,  293, RX: [aop: 0x0004]
<t:     295866>, access.c,  314, handle_incoming message
<t:     295870>, main.c,  312, Node 0x0100 alive with 0 active fault(s), RSSI: -65
2nd time:
<t:     447381>, main.c,  321, Button 0 pressed
<t:     447384>, main.c,  340, simple_on_off_client_set
<t:     447388>, simple_on_off_client.c,  191, <>before send_reliable_message
<t:     447391>, access.c, 1030, <> before packet_tx
<t:     447395>, transport.c, 1572, <> before upper_transport_tx
<t:     447399>, transport.c, 1427, <> before unsegmented_packet_tx
<t:     447402>, core_tx.c,   59, <> inside bearer_if_get
<t:     447405>, core_tx.c,   61, <> after NRF_MESH_ASSERT is_power_of_two
<t:     447409>, core_tx.c,   64, <> after NRF_MESH_ASSERT index < BEARER_COUNT
<t:     447421>, core_tx.c,  105, <> before bearer_if_get
<t:     447424>, core_tx.c,   59, <> inside bearer_if_get
<t:     447435>, nrf_mesh_sdk.c,  112, Softdevice assert: 4097:205414:256
Logs Server (Just receive events in first time):
1st time:
<t:          0>, main.c,  121, ----- BLE Mesh Light Switch Server Demo -----
<t:        515>, core_tx.c,   59, <> inside bearer_if_get
<t:        565>, device_state_manager.c, 1522, <>Setting dsm_init
<t:        572>, access.c,  595, <>Add flash manager success
<t:        578>, main.c,   85, Initializing and adding models
<t:        645>, main.c,   95, Successfully provisioned
<t:     468477>, access.c,  320, <>MESH_EVENT_CB_CALLED
<t:     468480>, access.c,  324, <>NRF_MESH_EVT_MESSAGE_RECEIVED
<t:     468483>, access.c,  285, <>mesh_msg_handle
<t:     468486>, access.c,  293, RX: [aop: 0x00C1]
<t:     468489>, access.c,  314, handle_incoming message
<t:     468493>, main.c,  112, simple_on_off_server_t set
<t:     468496>, main.c,  113, Got SET command to 0
<t:     468500>, transport.c, 1572, <> before upper_transport_tx
<t:     468504>, transport.c, 1427, <> before unsegmented_packet_tx
<t:     468507>, core_tx.c,   59, <> inside bearer_if_get
<t:     468526>, core_tx.c,  105, <> before bearer_if_get
<t:     468529>, core_tx.c,   59, <> inside bearer_if_get
2nd time: (nothing)
I already changed the client board with the server and it does not even work the first time i enter the number zero.
Client Logs:
<t:    4550381>, main.c,  321, Button 0 pressed
<t:    4550384>, main.c,  340, simple_on_off_client_set
<t:    4550388>, simple_on_off_client.c,  191, <>before send_reliable_message
<t:    4550392>, access.c, 1030, <> before packet_tx
<t:    4550395>, transport.c, 1572, <> before upper_transport_tx
<t:    4550399>, transport.c, 1427, <> before unsegmented_packet_tx
<t:    4550403>, core_tx.c,   59, <> inside bearer_if_get
<t:    4550421>, core_tx.c,  105, <> before bearer_if_get
<t:    4550425>, core_tx.c,   59, <> inside bearer_if_get
<t:    4550436>, core_tx.c,  109, <> after bearer_if_get
<t:    4550439>, network.c,  643, <> after core_tx_packet_send
<t:    4550442>, access.c,  461, <t:    4558973>, access.c, 1030, <> before packet_tx
<t:    4558977>, transport.c, 1572, <> before upper_transport_tx
<t:    4558981>, transport.c, 1427, <> before unsegmented_packet_tx
<t:    4558984>, core_tx.c,   59, <> inside bearer_if_get
<t:    4559003>, core_tx.c,  105, <> before bearer_if_get
<t:    4559006>, core_tx.c,   59, <> inside bearer_if_get
<t:    4559017>, core_tx.c,  109, <> after bearer_if_get
<t:    4559021>, network.c,  643, <> after core_tx_packet_send
<t:    4559024>, access.c,  461, <>TX: [aop: 0x00C1]
Server Logs:
<t:        519>, core_tx.c,   59, <> inside bearer_if_get
<t:        569>, device_state_manager.c, 1522, <>Setting dsm_init
<t:        576>, access.c,  595, <>Add flash manager success
<t:        581>, main.c,   85, Initializing and adding models
<t:        648>, main.c,   95, Successfully provisioned
