Power profiler kit higher current with a custom hardware
i'm developing an application with the NRF51822 device using the NRF51 development kit (DK). I bought a power profiler kit (PPK) to measure current for advertising and connection phases. When i measure current for the DK connected to the PPK, as showed in figure 9 in the PPK Manual, i get the expected current of around 4 uA between advertising and connection events.
When i connect a second DK with the same software as external device, as showed in figure 11, i get around 16 uA between events. I measure the same current when I use an external power supply (figure 12).
When i connect a multimeter in series to measure current between advertising events i measure 4 uA. Therefore i think that something is wrong with the configuration for external devices. I have prepared the DKs correctly (cut SB9)
Did i do something wrong or misunderstood the manual?
Edit: I've read in the NRF51 DK user guide, that the Interface cpu is powered when an external power supply is used. Then it draws around 20 uA. Is there an Option to power only the NRF51422 on the NRF51 DK?
Thank you in advice
Oliver
