How to extend mesh light_switch example with DFU
I am using the Mesh-SDK v1.0.0, the device is the nRF52832xxAA on PCA10040-Boards with the Softdevice s132. I am new to the development with BLE, and specially mesh. I have successfully done the DFU example, the application won't work, but the DFU looks like it was ok. Now my qestion:
  1. How could I extend the light_switch example to be DFU-ready? (primary target)
  2. Why is the example binary (app_green_s132.hex), which was a part of the DFU exmaple not working? (The board just stops working after the DFU) Is there any sourcecode for this application? Is inside the app_green.hex a build in DFU-functionality, to upgrade this app to a new version?
  3. Somwhere in the documentation stands, that the DFU functionality from the bootloader will be used for the application, how many space is needed in addition to lets say the light_switch-application to implement the DFU functionality? (I tried to update the DFU example with the examlpe itself, but the firmware looked to be too big, i've got a error message at the start of the download "Abort event. Reason: 0xD").
  4. Is there some documentation about the porting of the DFU functionality inside a mesh-application? Or the usage of the bootloader DFU inside the mesh-pplication code?
  • Hi Roland,
    After a successful DFU, the application should start automatically, so I don't think your DFU was successful unfortunately.
    Question 1: I would firstly get the DFU example to work. Then, I would take a look at the light switch source code (client & server) & compare this with the DFU source code.You can make a copy of the light switch example folder (under mesh_sdk/examples/) & call it light_switch_dfu for example. Then, try to add the DFU functionality into this new example by adding the functionality available in the DFU example that is not available in the light switch example. It will most likely help to really understand all of the code and all of the steps needed to setup a mesh network.
    Question 2: Taking a look at the DFU quick start guide, it seems they use the blinky example instead. Could you try running the DFU with this example & follow the steps in the DFU quick start guide & see if that works?
    Question 3: Are you referring to this?
    Question 4: It might be helpful to have a look at this link & use the Secure DFU application in the normal Nordic SDK. Also, take a look at the DFU quick start guide I mentioned in Question 2 & maybe this blog post will help.
    Hope that helps!
    thank you very much for the answer. I would like to clarify my questions a little more...
    Question 1: The new mesh-sdk (1.0.1) looks very optimistic, I had few sucessfully updates, but sometimes I get the 0xD and a abort, this happens on different update zip files. Also the initial update fails sometimes, I don't know why. Maybe I have some errors in the build procedure of the devicepage or the update zip file itself. Would have a look at them? Should I send them to you?
    Question 2: Now I have some successes on the new mesh-sdk. So I got some hope, that all will be fine, but one more thing don't let me sleep pacefully, look at the Question 3. point.
    Question 3: I refere to the README.md file in the sdk 1.0.1 in the subfolder /mesh/bootloader. I got a device with BLE, with the normal SDK and a booltoader, this device is in production and no changes should be made, now I would like to make a DFU with a new Softdevice and a mesh-functionality. So I have to change the bootloader, to get the full mesh functionality. The usual bootloader erases the application, updates the softdevice and the bootloader. Now I have a dvice with no application. In the README.md from the booltoader under the point "## Side-by-side DFU" is stated, that "The bootloader is also capable of operating without an application, as a recovery mechanism from a faulty application." but under the "## Limitations" you could find the note "- The bootloader is not able to host a DFU transfer on its own, it depends on an external entity initiating and controlling the transfer." Could you tell me please which of the two statements is true?
    Question 4: Now I have some more overview, I will hope I get it to work, if I got the other things to work.
    I am looking forward to hear from you.
  • Q1: Do you have any more information regarding the 0XD error? Do you have an error log you could post to this case? I have not been able to find this error code.
    Q3: Both of the statements are true. The bootloader is able to operate without an application, but requires a smartphone for example to act as the dfu controller (i.e. the device that initiates the dfu transfer).
  • Hello and many thanks for the answer.
    Q1: I have done some testing, the error code comes on the debug output during the start of an update process:
     0> <t:         57>, main.c,  192, ----- Bluetooth Mesh DFU Example -----
     0> <t:         60>, nrf_mesh_sdk.c,  187, Initializing softdevice
     0> <t:          0>, nrf_mesh_sdk.c,  122, Initializing SoftDevice...
     0> <t:          2>, nrf_mesh_sdk.c,  131, Ram base: 0x200031B0
     0> <t:         19>, nrf_mesh_sdk.c,  197, Initializing mesh stack
     0> <t:        592>, nrf_mesh_dfu.c,  528, 	RADIO TX! SLOT 0, count 255, interval: periodic, handle: FFFE
     0> <t:        597>, nrf_mesh_dfu.c,  561, 	SERIAL TX!
     0> <t:        603>, nrf_mesh_sdk.c,  205, Enabling mesh stack
     0> <t:        608>, main.c,  220, Initialization complete!
     0> <t:     465395>, nrf_mesh_dfu.c,  390, 	New firmware!
     0> <t:     465397>, nrf_mesh_dfu.c,  528, 	RADIO TX! SLOT 0, count 255, interval: periodic, handle: FFFD
     0> <t:     465401>, nrf_mesh_dfu.c,  534, Killing a TX slot prematurely (repeats done: 2).
     0> <t:     465404>, nrf_mesh_dfu.c,  561, 	SERIAL TX!
     0> <t:     531827>, nrf_mesh_dfu.c,  528, 	RADIO TX! SLOT 0, count 255, interval: periodic, handle: FFFD
     0> <t:     531831>, nrf_mesh_dfu.c,  534, Killing a TX slot prematurely (repeats done: 0).
     0> <t:     531834>, nrf_mesh_dfu.c,  561, 	SERIAL TX!
     0> <t:     596434>, nrf_mesh_dfu.c,  383, 	Abort event. Reason: 0xD
     0> <t:     596437>, nrf_mesh_dfu.c,  528, 	RADIO TX! SLOT 0, count 255, interval: periodic, handle: FFFE
     0> <t:     596440>, nrf_mesh_dfu.c,  534, Killing a TX slot prematurely (repeats done: 20).
     0> <t:     596443>, nrf_mesh_dfu.c,  561, 	SERIAL TX!
    I wanted exactly to know which error code was thrown, so I extended the debug output with the following lines in the example in the file nrf_mesh_dfu.c:
    static uint32_t dfu_evt_handler(bl_evt_t* p_evt)
        uint32_t return_code = NRF_SUCCESS;
        switch (p_evt->type)
            case BL_EVT_TYPE_ECHO:
                __LOG(LOG_SRC_DFU, LOG_LEVEL_INFO, "\tEcho: %s\n", p_evt->params.echo.str);
            case BL_EVT_TYPE_DFU_ABORT:
    				if ( p_evt->params.dfu.abort.reason == NRF_MESH_DFU_END_FWID_VALID )
    					__LOG(LOG_SRC_DFU, LOG_LEVEL_INFO, "\tAbort event. invalid FW: 0x%x\n", p_evt->params.dfu.abort.reason);
    				else if ( p_evt->params.dfu.abort.reason == NRF_MESH_DFU_END_APP_ABORT )
    					__LOG(LOG_SRC_DFU, LOG_LEVEL_INFO, "\tAbort event. App abort Reason: 0x%x\n", p_evt->params.dfu.abort.reason);
    				else if ( p_evt->params.dfu.abort.reason == NRF_MESH_DFU_END_ERROR_PACKET_LOSS )
    					__LOG(LOG_SRC_DFU, LOG_LEVEL_INFO, "\tAbort event. packet loss Reason: 0x%x\n", p_evt->params.dfu.abort.reason);
    				else if ( p_evt->params.dfu.abort.reason == NRF_MESH_DFU_END_ERROR_UNAUTHORIZED )
    					__LOG(LOG_SRC_DFU, LOG_LEVEL_INFO, "\tAbort event. unauthorized Reason: 0x%x\n", p_evt->params.dfu.abort.reason);
    				else if ( p_evt->params.dfu.abort.reason == NRF_MESH_DFU_END_ERROR_NO_START )
    					__LOG(LOG_SRC_DFU, LOG_LEVEL_INFO, "\tAbort event. start packet missing Reason: 0x%x\n", p_evt->params.dfu.abort.reason);
    				else if ( p_evt->params.dfu.abort.reason == NRF_MESH_DFU_END_ERROR_TIMEOUT )
    					__LOG(LOG_SRC_DFU, LOG_LEVEL_INFO, "\tAbort event. packet timeout Reason: 0x%x\n", p_evt->params.dfu.abort.reason);
    				else if ( p_evt->params.dfu.abort.reason == NRF_MESH_DFU_END_ERROR_NO_MEM )
    					__LOG(LOG_SRC_DFU, LOG_LEVEL_INFO, "\tAbort event. not anough memory Reason: 0x%x\n", p_evt->params.dfu.abort.reason);
    				else if ( p_evt->params.dfu.abort.reason == NRF_MESH_DFU_END_ERROR_INVALID_PERSISTENT_STORAGE )
    					__LOG(LOG_SRC_DFU, LOG_LEVEL_INFO, "\tAbort event. data errorin devicepage Reason: 0x%x\n", p_evt->params.dfu.abort.reason);
    				else if ( p_evt->params.dfu.abort.reason == NRF_MESH_DFU_END_ERROR_SEGMENT_VIOLATION )
    					__LOG(LOG_SRC_DFU, LOG_LEVEL_INFO, "\tAbort event. error in flash section Reason: 0x%x\n", p_evt->params.dfu.abort.reason);
    				else if ( p_evt->params.dfu.abort.reason == NRF_MESH_DFU_END_ERROR_MBR_CALL_FAILED )
    					__LOG(LOG_SRC_DFU, LOG_LEVEL_INFO, "\tAbort event. mbr call fails Reason: 0x%x\n", p_evt->params.dfu.abort.reason);
    				else if ( p_evt->params.dfu.abort.reason == NRF_MESH_DFU_END_ERROR_INVALID_TRANSFER )
    					__LOG(LOG_SRC_DFU, LOG_LEVEL_INFO, "\tAbort event. invalid transfere Reason: 0x%x\n", p_evt->params.dfu.abort.reason);
    				else if ( p_evt->params.dfu.abort.reason == NRF_MESH_DFU_END_ERROR_BANK_IN_BOOTLOADER_AREA )
    					__LOG(LOG_SRC_DFU, LOG_LEVEL_INFO, "\tAbort event. Bank in bl area Reason: 0x%x\n", p_evt->params.dfu.abort.reason);
    				else if ( p_evt->params.dfu.abort.reason > NRF_MESH_DFU_END_ERROR_BANK_IN_BOOTLOADER_AREA )
    					__LOG(LOG_SRC_DFU, LOG_LEVEL_INFO, "\tAbort event. Bank and Dest ovl Reason: 0x%x\n", p_evt->params.dfu.abort.reason);
    					__LOG(LOG_SRC_DFU, LOG_LEVEL_INFO, "\tAbort event. Reason: 0x%x\n", p_evt->params.dfu.abort.reason);
                    end_transfer(p_evt->params.dfu.abort.reason);
    from now on I've got no error anymore...
    dfu_no_serial_nrf52832_xxAA_s132_5.0.0_slow.hex
    This hex-file makes trouble
    dfu_no_serial_nrf52832_xxAA_s132_5.0.0.hex
    this one is ok...
    Q3:
    I made one test on the device without a application.
    I have flashed one device with the softdevice: "s132_nrf52_5.0.0_softdevice.hex", than this booltoader "mesh_bootloader_serial_gccarmemb_nrf52832_xxAA.hex", which is a part of the mesh-SDK 1.0.1 and a devicepage:
    device_page_nrf52832_xxAA_s132_5.0.0_ID2_V1.hex
    after a reset it starts sending a DFU Ready APP (Handle 0xFFFD), the counterpart (another board with flashed serial mesh-dfu, this setup worked during an update with loaded application on the target) won't start the upload, the output of the serial board looks like that:
     0> <t:         92>, main.c,  192, ----- Bluetooth Mesh DFU Example -----
     0> <t:         94>, main.c,  193, ----- Version SECHS -----
     0> <t:         96>, main.c,  208, rom_base   23241
     0> <t:         98>, main.c,  209, rom_end    41148
     0> <t:        100>, main.c,  210, rom_length 1DF07
     0> <t:        102>, main.c,  211, bank_addr   42000
     0> <t:        104>, nrf_mesh_sdk.c,  187, Initializing softdevice
     0> <t:        587>, nrf_mesh_dfu.c,  601, 	RADIO TX! SLOT 0, count 255, interval: periodic, handle: FFFE
     0> <t:        591>, nrf_mesh_dfu.c,  634, 	SERIAL TX!
     0> <t:        598>, nrf_mesh_sdk.c,  205, Enabling mesh stack
     0> <t:        602>, serial_handler_prov.c,  212, Generating encryption keypair...
     0> <t:       5078>, main.c,  223, Enabling serial interface...
     0> <t:       5081>, main.c,  227, Initialization complete!
     0> <t:       8745>, nrf_mesh_dfu.c,  463, 	New firmware!
     0> <t:       8748>, nrf_mesh_dfu.c,  601, 	RADIO TX! SLOT 0, count 255, interval: periodic, handle: FFFD
     0> <t:       8751>, nrf_mesh_dfu.c,  607, Killing a TX slot prematurely (repeats done: 1).
     0> <t:       8754>, nrf_mesh_dfu.c,  634, 	SERIAL TX!
    the last 4 lines comes directly after powering up the target baord. The call to the nrfutil gives the following output:
    Upgrading target on COM40 with DFU package D:\Work\BLE\nrf5_SDK_for_Mesh_v1.0.1_
    src\build\examples\dfu\dfu_testID2V2_fast.zip. Flow control is enabled.
      [------------------------------------]    0%
    Failed to upgrade target. Error is: Device returned status code ERROR_INVALID_DA
    TA (135) on a DFU data packet.
    Possible causes:
    - bootloader, SoftDevice or application on target does not match the requirement
    s in the DFU package.
    - baud rate or flow control is not the same as in the target bootloader.
    - target is not in DFU mode. If using the SDK examples, press Button 4 and RESET
     and release both to enter DFU mode.
      File "__main__.py", line 360, in <module>
      File "click\core.pyc", line 700, in __call__
      File "click\core.pyc", line 680, in main
      File "click\core.pyc", line 1027, in invoke
      File "click\core.pyc", line 873, in invoke
      File "click\core.pyc", line 508, in invoke
      File "__main__.py", line 350, in serial
    NameError: global name 'exit' is not defined
    Drücken Sie eine beliebige Taste . . .
    I have no idea what went wrong, this setup is working well, when the target is flashed with an application, what should I do to became this scenario of upgrade an ble-device to work in an mesh? The update description says, that I can update the booltoader and the softdevice at once with the non-mesh booltoader, than I will have the mesh-bootloader and the new softdevice, without a application. Is this correct, or did I have made some error in my thoughts?
    Have a nice weekend.
  • Sorry for the delayed response.
    Q1: What is the difference between the hex file that works & the one that doesn't work? Have you only changed the debugging information & added some log prints?
    Q3: Did you have a look at the secure dfu bootloader blog post I mentioned? Did you create the public & private keys required for the bootloader? This link explains the process quite well. You should be able to update the bootloader & softdevice with the non-mesh secure dfu bootloader no problem. Again, take a look at the secure dfu blog post.
