On nrf52832 and nRF5 Mesh1.0.0
When running idle state(not RX/TX), current comsumption is over 400uA.
And every 100ms, CPU is wake up.(small working.)
What happen?
What happen?
Well, you haven't given us a lot to go on but here is one guess: Perhaps you have a TIMER peripheral and the HF clock running? That would get you pretty darn close to 400uA.
What peripherals are you using? Are you sure you are disabling them or turning them off if you can? What current are you expecting?
I don't know how work TIMER / HF clock on nrfmesh. I expect under 100uA on IDLE.
I guess, always nrfmesh use timeslot, which RX/TX is used.
Add, my environment is
nrf52832 module (no-famous).
SoftDevice S132 5.1.0
SDK14.2
nrf mesh 1.0.0 porting for SDK14.2
FreeRTOS environment
I try,
example/ble_app_beacon : current comsumption is 100uA.
FreeRTOS environment without nrf mesh : current comsumption is 100uA.
I use FreeRTOS and BSP's(LED and button).
So, RTC1/GPIO/GPIOTE.
And
Another problem, (every 100ms wakeup) I try nrf5_SDK_for_Mesh_v1.0.0_src/examples/beaconing. Modified, 1. main.c: beacon interval change to 5000ms. 2. nrf_mesh.c:nrf_mesh_enable() scanner_enable() is comment out.(not scan) When run the program on my nrf52832 board, Every 100ms, NRF_RADIO_CALLBACK_SIGNAL_TYPE_TIMER0 event occured. Timeslot request and ranges from 100 us to 100 ms. So that, nrf mesh is wakeup every 100ms, Whether scanner enable or disable. And increase a little current comsumption. Is this really?
Yes, the mesh stack uses the timeslot API. The timeslot API uses a timer and this requires the HF clock to be running at all times. This is the reason for the relatively high current consumption.
