SAADC offset calibration for each input?
Some questions regarding offset calibration when doing single samples (or burst mode) from multiple input pins:
  1. Can SAADC offset calibration be performed after SAADC initialization (nrf_drv_saadc_init), but prior to channel initialization (nrf_drv_saadc_channel_init)? My hunch is no, since offset calibration time is dependent on the acquisition time, which is a channel-specific parameter.
  2. Must the acquisition time used for offset calibration match the acq time used for the channel (or can I shorten during cal)? What are the implications of different times?
  3. Does SAADC offset calibration need to be performed for each input (AINx), or does the offset apply to all input pins? i.e. If I intend to use multiple AIN inputs (AIN1, AIN2, etc), do I need to call nrf_drv_saadc_calibrate_offset for each input (after each channel initialization)?
I would like to do infrequent sampling of multiple analog inputs. I'm using one SAADC channel, and reconfiguring it with each input prior to the sample. Can I do this:
  • Init SAADC (nrf_drv_saadc_init)
  • Set up a bogus channel using the desired acq time for offfset cal
  • Calibrate offset (nrf_drv_saadc_calibrate_offset)
  • Init Channel 1 with AIN1 (nrf_drv_saadc_channel_init)
  • Sample Channel 1 (nrf_drv_saadc_sample)
  • Uninit Channel 1
  • Init Channel 1 with AIN2 (nrf_drv_saadc_channel_init)
  • Uninit Channel 1
  • ...Repeat for remaining AINx...
  • Uninit SAADC (nrf_drv_saadc_uninit)
  • Sleep until next interval
Or do I need to rerun calibrate offset with each new AINx?
