Problems about mesh
Board:custom board Mesh SDK: V1.0.0 IDE:SEGGER Embedded
Problem a: When I test the steps specified by “Interactive PyACI”, there is A certain probability of Provisioning failure.When the serial port printed "EcdhSecret: {'context': 0}",the program will blocking untill Provisioning link closed.I want to known why?
   serial prot log:
          1.Link established
          2.Received capabilities
          3.Number of elements: 2
          4.OobUse: {'context': 0}
          5.ECDH request received
          6.EcdhSecret: {'context': 0}
          7.Provisioning link closed
  • Hi Beike,
    Which firmware you run on the provisionee ? Could you post the full log ?
    How often do you see the issue ?
  • firmware :S132_5.0.0
    the log:
    client:
    2018-01-31 17:17:10,179 - INFO - COM7: Provision: {'context': 0}
    2018-01-31 17:17:10,234 - INFO - COM7: Link established
    2018-01-31 17:17:10,274 - INFO - COM7: Received capabilities
    2018-01-31 17:17:10,275 - INFO - COM7: Number of elements: 2
    2018-01-31 17:17:10,277 - INFO - COM7: OobUse: {'context': 0}
    2018-01-31 17:17:12,445 - INFO - COM7: ECDH request received
    2018-01-31 17:17:12,450 - INFO - COM7: EcdhSecret: {'context': 0}
    2018-01-31 17:18:12,474 - INFO - COM7: Provisioning link closed
    server:
    2018-01-31 17:17:10,214 - INFO - COM9: Link established
    2018-01-31 17:17:12,453 - INFO - COM9: ECDH request received
    2018-01-31 17:17:12,458 - INFO - COM9: EcdhSecret: {'context': 0}
    2018-01-31 17:18:12,539 - INFO - COM9: Provisioning link closed
  • Sorry for the late reply, Hung has been travelling. Is this still a problem? Could you try with Mesh SDK v1.0.1? Are you following example here? Your logs doesn't look the same.
  • Hi Petter,
    I got the same result when I followed the Provisioning example of Interactive PyACI page.
    From the log, it seems the provision sequence can not be completed.
    Could you give me some comment how to debug this issue ? Thanks.
    Microsoft Windows [版本 10.0.16299.371]
    (c) 2017 Microsoft Corporation. 著作權所有,並保留一切權利。
    C:\NORDIC\nrf5_SDK_for_Mesh_v1.0.1_src\scripts\interactive_pyaci
    C:\\NORDIC\nrf5_SDK_for_Mesh_v1.0.1_src\scripts\interactive_pyaci>python interactive_pyaci.py -d COM12 COM13
        To control your device, use d[x], where x is the device index.
        Devices are indexed based on the order of the COM ports specified by the -d option.
        The first device, d[0], can also be accessed using device.
        Type d[x]. and hit tab to see the available methods.
    2018-04-18 13:07:04,777 - ERROR - COM12: Exception in pkt handler <bound method Interactive.__event_handler of <__main__.Interactive object at 0x05709270>>
    2018-04-18 13:07:04,780 - ERROR - COM12: traceback: Traceback (most recent call last):
      File "C:\NORDIC\nrf5_SDK_for_Mesh_v1.0.1_src\scripts\interactive_pyaci\aci\aci_uart.py", line 88, in process_packet
        fun(packet)
      File "interactive_pyaci.py", line 152, in __event_handler
        if self._event_filter_enabled and event._opcode in self._event_filter:
    AttributeError: 'Interactive' object has no attribute '_event_filter_enabled'
    2018-04-18 13:07:04,781 - ERROR - COM13: Exception in pkt handler <bound method Interactive.__event_handler of <__main__.Interactive object at 0x05526F50>>
    2018-04-18 13:07:04,786 - ERROR - COM13: traceback: Traceback (most recent call last):
        fun(packet)
    Activating auto-logging. Current session state plus future input saved.
    Filename       : interactive_session_18-108-13-7.log
    Mode           : backup
    Output logging : False
    Raw input log  : False
    Timestamping   : False
    State          : active
    Python 3.6.5 (v3.6.5:f59c0932b4, Mar 28 2018, 16:07:46) [MSC v.1900 32 bit (Intel)]
    Type 'copyright', 'credits' or 'license' for more information
    IPython 6.3.1 -- An enhanced Interactive Python. Type '?' for help.
    In [1]: p = Provisioner(d[0])
    I2018-04-18 13:10:38,722 - INFO - COM12: Successn [
    2]:2018-04-18 13:10:38,728 - INFO - COM12: Success 2018-04-18 13:10:38,730 - INFO - COM12: SubnetAdd: {'subnet_handle': 0}
    In [2]:
    In [2]: a = Provisionee(d[1])
    In2018-04-18 13:10:52,677 - INFO - COM13: Success [
    3]:2018-04-18 13:10:52,684 - INFO - COM13: In [3]:
    In [3]: p.scan_start()
    2018-04-18 13:11:02,681 - INFO - COM12: Success
    In [4]:
    In [4]: a.listen()
    2018-04-18 13:11:13,590 - INFO - COM13: Success
    In [5]: 2018-04-18 13:11:14,946 - INFO - COM12: Received UUID B32DE29E978FC2181368C92FFD5B5DEB with RSSI: -231 dB
    In [5]:
    In [5]: p.provision()
    I2018-04-18 13:11:25,533 - INFO - COM12: Provision: {'context': 0}n
    [6]:    2018-04-18 13:11:25,550 - INFO - COM13: Link established
    2018-04-18 13:11:25,562 - INFO - COM12: Link established
    2018-04-18 13:11:25,607 - INFO - COM12: Received capabilities
    2018-04-18 13:11:25,608 - INFO - COM12: Number of elements: 2
    2018-04-18 13:11:25,612 - INFO - COM12: OobUse: {'context': 0}
    2018-04-18 13:11:27,771 - INFO - COM12: ECDH request received
    2018-04-18 13:11:27,784 - INFO - COM12: EcdhSecret: {'context': 0}
    2018-04-18 13:11:27,791 - INFO - COM13: ECDH request received
    2018-04-18 13:11:27,804 - INFO - COM13: EcdhSecret: {'context': 0}
    2018-04-18 13:12:27,802 - INFO - COM12: Provisioning link closed
    2018-04-18 13:12:27,877 - INFO - COM13: Provisioning link closed
