Nordic,
I am using the BLE Shield v2 and the Arduino Due board to transmit accelerometer/gyro data to an Android tablet app that plots this data. I had this working fine until I attempted to rename the board by calling the function "ble_set_name()" and downloading nRFgoStudio (However, I did not modify the ble_shield.xml file). I'm not sure what happened or why, but after I messed with that function and downloaded nRFgoStudio, I have not been able to get the BLE shield to broadcast anything anymore. I have tried re-downloading/re-importing the BLE Shield libraries and the Nordic BLE libraries (slightly modifying these libraries again to work with the Arduino Due board), but still no luck. After doing some investigating, I have found that when I run my program on the board, it gets stuck when calling "ble_begin()". After testing and digging into the library files, I found that it gets stuck in a while(1) in the function "lib_aci_board_init(aci_state_t)" within lib_aci.cpp because the ACI queue is always empty (specifically, aci_q->head == aci_q->tail). Obviously, the ACI queue should not always be empty and these files worked fine before. When I turn on the debug printing for ACI commands, it returns "C1 :1, E,". I'm at a loss of what happened here and why I can no longer get the BLE shield to work. The BLE shield physically appears that it is working, the Arduino Due board is working fine, and I did not change anything physically on the hardware, but I'm not completely sure if my problem is software or hardware related. Any suggestions would be helpful. Thanks!
Devon
