TickTimer Accuracy
  • We are using SD110 with SDK 7.2.0 in our application
  • Our application needs to be quite accurate in timing
  • We set out to determine what the accuracy of the TickTimer was, which is provided by the SD (110 in our case)
  • Our hardwaresetup is shown in the attached file, "nRF51TimerTickAccuracyTestSetup.pdf"
    • What you see is a 1MHz oscillator (accurate to a few PPM)
    • it is connected to a 12-stage counter (hardware, so NO time lost due to freq. division)
    • I take the 12th stage output (which is 1MHz / 2^12 => 244 Hz) and connect it to P0.0 on the nRF
  • The code (shown in file "nRF51TimerTickAccuracyTest.pdf") does the following:
    • Set up GPIOTE for my input pin (P0.0)
    • Init Timer2 to be a counter in 16 bit mode
    • Configure the PPI channel 0 to get Events in from P0.0 (NRF_PPI->CH[0].EEP)
    • Configure the PPI channel 0 to count up on T2 (NRF_PPI->CH[0].TEP)
  • All this works very nicely, thanks to your previous help!!
  • I run the nRF without ANY BLE activity at all
    • This should mean that the SD is quite undisturbed by asynchronous events like BLE traffic, etc.
  • I expect to see CC[0] get a value close to 14,604:
    • every sec is 1,000,000 / 2^12 = 244 counts / second
    • 244 * 60 seconds = 14,604 counts / minute
  • HOWEVER, what I actually see in the CC[0] register (using the Keil debugger) is 14,751 counts
    • This is the equivalent of 420,000 counts difference between expected and actual
    • this is 0.42 seconds gained every minute!
  • Adding BLE doesn't change this number at all
  • My question is:
    • What is causing this 420mSec per minute increase?
    • BTW, this is constant across many boards...
    • Is there a way to fine-tune the timer such that it is more accurate than this?
Files attached
Thanks for your help!
nRFTimerTickAccuracyTest.pdf
